Thread: help code P1336 CMP?
Results 1 to 16 of 16
kurt5153 help code P1336 CMP? 09-11-2011, 11:27 PM
KeithGTP03 Re: help code P1336 CMP? 09-11-2011, 11:30 PM
Fivefingerdeathpunch Re: help code P1336 CMP? 09-11-2011, 11:30 PM
kurt5153 Re: help code P1336 CMP? 09-12-2011, 12:12 AM
Slick2500 Re: help code P1336 CMP? 09-12-2011, 12:25 AM
KeithGTP03 Re: help code P1336 CMP? 09-13-2011, 11:45 PM
Fivefingerdeathpunch Re: help code P1336 CMP? 09-14-2011, 01:04 PM
kurt5153 Re: help code P1336 CMP? 09-14-2011, 02:08 PM
kurt5153 Re: help code P1336 CMP? 09-12-2011, 07:13 AM
kurt5153 Re: help code P1336 CMP? 09-13-2011, 11:39 PM
kurt5153 Re: help code P1336 CMP? 09-17-2011, 08:29 AM
Fivefingerdeathpunch Re: help code P1336 CMP? 09-17-2011, 12:22 PM
kyleinkman Re: help code P1336 CMP? 09-17-2011, 06:20 PM
kurt5153 Re: help code P1336 CMP? 09-18-2011, 06:09 PM
kurt5153 Re: help code P1336 CMP? 09-18-2011, 10:28 PM
kurt5153 Bump I still need help with... 04-21-2012, 06:17 PM
  1. #1 help code P1336 CMP?
    SE Level Member kurt5153's Avatar
    Apple Valley,Ca 92308
    i finely got time to work on my gtp, i changed my s/c snout and tuned ecu but now i get this P1336 code, my chilton manual doesnt have it listed. my car never had this issue with my other ecu could that be it?
  2. #2 Re: help code P1336 CMP?
    Houston
    I think you need a case relearn
  3. #3 Re: help code P1336 CMP?
    says its a crank postion sensor issue.
    Ive read that doing a crank (case) relearn may solve the problem.
  4. #4 Re: help code P1336 CMP?
    how do you do that?
  5. #5 Re: help code P1336 CMP?
    This was the first thing that came up on Google "P1336 code means Crankshaft and camshaft sensors out of sync"
    To do a case learn you need to take it in to a shop or find someone who has a tuner.
  6. #6 Re: help code P1336 CMP?
    Houston
    Quote Originally Posted by slick2500 View Post
    This
  7. #7 Re: help code P1336 CMP?
    if you own a aeroforce gauge you can do your own case learn.
  8. #8 Re: help code P1336 CMP?
    How so?
  9. #9 Re: help code P1336 CMP?
    Koo thanks, ill hit up reptile.
  10. #10 Re: help code P1336 CMP?
    Okay so he said all I have to do is perform a crank case position relearn.how do I do that and can I drive it without issues thxs!
  11. #11 Re: help code P1336 CMP?
    So how do I do this relearn with my Aeroforce inspector gauge?
  12. #12 Re: help code P1336 CMP?
    on the menu page there should be and option way down at the bottom I think where it say case learn or something.
    Start going into different parts of the aeroforce and you will find it, then it tells you how to perform it.
  13. #13 Re: help code P1336 CMP?
    Donating Users kyleinkman's Avatar
    May 2011
    canada
    P1336
    Trouble Code Conditions:
    DTC P0336, P0341and P1374 not set, engine started, ECT sensor more than 158ºF, and the PCM did not detect any CKP variation values. The Crankshaft Position system variation-learning feature is used to calculate reference period errors caused by slight tolerance variations in the crankshaft, and the CKP sensor(s). The calculated error allows the PCM to accurately compensate for reference period variations to enhance the Misfire Detection capability of the system.
    Possible Causes:
    • Set the parking brake and block the drive wheels for safety.
    • Verify the hood is closed.
    • Read the trouble codes. If a code is set, refer to that code.
    • Start the engine. Allow engine temperature to reach at least 158ºF (70ºC). Then key off.
    • Select Crankshaft Position Variation Learn procedure on Scan Tool & start the vehicle.
    • Apply the brake pedal firmly and verify the selector is in Park.
    • Increase accelerator pedal position until fuel cutoff is reached at the test rpm (e.g., 5150). Quickly release the accelerator pedal after fuel cutoff is reached. The CKP system variation compensating values are learned when the engine speed (rpm) decreases back to idle speed and the procedure terminates
    MODS:
    K&N Intake, Removed mesh air screen, flipped mounts, egr delete, NGK Cooler plugs, NGK wires, 3" pipe, Pacesetter headers, Flowmaster super 44's , 3.4 pulley, 18 inch Fast wheels rims, NanKing ns II tires, Overkill tune, comp cams. junk yard short block
  14. #14 Re: help code P1336 CMP?
    Thxs guys, but I can't find anything n my Aeroforce nor on my scanner to do it! :-(
  15. #15 Re: help code P1336 CMP?
    Okay well I found it on the Aeroforce but the code doesn't want to go away or I'm not doing it right but n my brother have tried but its a no no :-(
    Bump I still need help with this
    Sent from my Galaxy Nexus using Tapatalk 2
  1. help! code po 716
    By SteveCZ28 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2011, 07:38 AM
  2. does anyone know how to fix this code?
    By shsfootball57 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2011, 12:33 PM
  3. P1336 code with new pcm
    By SleeperGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2011, 01:05 PM
  4. RPO code tag
    By Wicked13 in forum General Tech Discussion
    Last Post: 05-04-2010, 07:34 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
