Thread: crankshaft
Results 1 to 20 of 24
  1. #1 crankshaft
    Aug 2011
    South Carolina/Georgia
    Another question, where is the crankshaft position sensor. ( 2000 grand prix gt)
  2. #2 Re: crankshaft
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    "The sensor in the Grand Prix is a 3-inch cylindrical sensor located on the side of the engine facing the firewall, directly under the exhaust manifold. It is inserted into the block and held in with a 10-mm bolt. It is a 3-wire sensor with one purple, one light green and one light blue with a black stripe wire."
  3. #3 Re: crankshaft
    Moved.
    This isn't a How To...
  4. #4 Re: crankshaft
    It's right behind the harmonic balancer and the plastic shield
    Shield off
    The 2 13mm bolts should be retorqued to 13 ft lbs.
  5. #5 Re: crankshaft
    Aug 2011
    I apologize if I put in the wrong spot.
    I had and SES and was told that it wad the crankshaft position sensor.
    If it was faulty, would I cause my RPM needle to stop working while the vehicle is running??
    I have pictures, but I don't know how to upload them from the phone, yet.
  6. #6 Re: crankshaft
    Yes...the tach tends to bounce and not operate.
    Replace it...clear the code...then get back to us
  7. #7 Re: crankshaft
    Aug 2011
    Not crazy, but this may need to be done by a professional.
  8. #8 Re: crankshaft
    It's easy...it doesn't.
  9. #9 Re: crankshaft
    Aug 2011
    Lol, we will see. No other assemblies need to be removed, right???
  10. #10 Re: crankshaft
    Jack up the passenger side and remove the tire (5 x 19mm)
    Remove plastic splash shield keeping you from seeing the balancer (trim popper tool)
    Using a balancer puller and 3 x M6 x 1.00 x 75mm bolts pull the balancer
    Disconnect the wiring to the sensor
    Remove 2 x 13mm bolts, wiggle sensor off
    Install the reverse using 13 ft lbs of torque for the sensor bolts, remember to push and turn the balancer to get it engaged on the key before you bolt it up.
    With air tools in my garage it's a 15 minute job.
  11. #11 Re: crankshaft
    Aug 2011
    Got a pic of the puller, I'm fresh outta Germany (military). I don't have that stuff. Lol
  12. #12 Re: crankshaft
    Looks just like a Y to have bolts going into the three holes of the balancer. You can typically "borrow" one from most parts stores as a loaner tool. Biggest thing is to ensure it's got the three M6 x 1.00 x 75mm or so bolts. Because most kits don't have those bolts.
  13. #13 Re: crankshaft
    Aug 2011
    Wait, so the balancer is only 'engaged' in there??? So I should be able to pull it out ??(no pun intented).
  14. #14 Re: crankshaft
    No, there's a bolt, I think 22/24mm that you have to take off to get the balancer off.
  15. #15 Re: crankshaft
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Shield off
    Question, how are you able to see that balancer so clearly, Ive got the wheel off and the only plastic that comes off does not give me that vantage?
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  16. #16 Re: crankshaft
    St. Louis
    The balancer is part of the crank pulley. It's all one piece. Remove the crank pulley/balancer assembly and it will look like the pic.
  17. #17 Re: crankshaft
    Marysville WA
    Quote Originally Posted by FordMan77 View Post
    Any suggestions on how to break that balancer bolt
  18. #18 Re: crankshaft
    St. Louis
    Yes. Not a suggestion, just the technique.
    Remove the inspection cover from the transmission. Little black plastic cover on the bottom. Here you see the flywheel. Get a pair of vicegrips and clamp them onto the flywheel good and tight (don't clamp the teeth of the flywheel). Now, go back to the crank bolt. If you have access to a GOOD air impact then have at it. If not, then a cheater/breaker bar is your friend. Get the correct size socket on there and turn it until you feel the motor lock. This is the vicegrips holding the motor from spinning backwards. Then just give it hell until it pops loose. That bolts has around 110ft/lbs on it and some orange loctite from factory so it can be a b**ch. DO NOT heat the bolt w/ a torch or you risk the front crank seal.
    One note- When reinstalling the balancer be 100% sure you line the slot on the inside of the balancer up w/ the key in the crankshaft or you are going to have big problems. The balancer should push on if you wiggle it a bit, then drive it the rest of the way on w/ the bolt. The bolt is supposedly not reuseable per GM, but you can reuse it if you like. I did on 2 of my cars (both 3800's) and no issues. Just be sure to get the torque correct once its back on again. The specs are around here somewhere. Do a search and it should come up.
    Be sure to remove the vicegrips once the bolt is tightend up again.
  19. #19 Re: crankshaft
    Marysville WA
    Is this what you mean? Ive never taken this off anything I need to be on the look out for when I give this a go? What is the "Little black plastic cover on the bottom"?
  20. #20 Re: crankshaft
    St. Louis
    Yep. See where the oil pan on the engine meets the transmission? That black plastic cover with the 2 bolts in it (should be 10mm IIRC). Remove that and you will be able to see the bottom of the flywheel.
  1. Threw crankshaft sensor
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-06-2011, 02:29 PM
  2. Crankshaft Balancer went bye-bye
    By cherokeegurl77 in forum Forum Bugs/Suggestions
    Last Post: 10-31-2009, 01:58 PM
  3. Crankshaft Balancer went bye-bye
    Last Post: 10-31-2009, 01:35 PM
  4. End play in crankshaft?
    By BackInBlack in forum Off Topic Discussion
    Last Post: 11-01-2008, 08:04 PM
