Thread: crankshaft
Results 1 to 20 of 24
  1. #1 Re: crankshaft
    St. Louis
    Yep. See where the oil pan on the engine meets the transmission? That black plastic cover with the 2 bolts in it (should be 10mm IIRC). Remove that and you will be able to see the bottom of the flywheel.
  2. #2 Re: crankshaft
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Quote Originally Posted by FordMan77 View Post
    When I remove the transmission inspection plate I think thats what its called, is there a seal I need to look out for and or replace? Will clearly see where to clamp the vice grip or are there parts of the flywheel I dont want to touch. Im sure Ill know once I crack it open but im just trying to get as much knowledge as possible prior to tear down.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  1. Threw crankshaft sensor
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-06-2011, 02:29 PM
  2. Crankshaft Balancer went bye-bye
    By cherokeegurl77 in forum Forum Bugs/Suggestions
    Last Post: 10-31-2009, 01:58 PM
  3. Crankshaft Balancer went bye-bye
    Last Post: 10-31-2009, 01:35 PM
  4. End play in crankshaft?
    By BackInBlack in forum Off Topic Discussion
    Last Post: 11-01-2008, 08:04 PM
