Thread: Blinking Check Engine Light
Results 1 to 20 of 30
  1. #1 Re: Blinking Check Engine Light
    Jun 2011
    Detroit, MI
    I'm justsaying I got my car checked out before I bought it and the mechanic said it was good. 3 weeks after, I blew the engine up. I went WOT at 80 MPH, and coolant leaked into the engine, so I guess you could say it happens only at "high speeds". AND just because you see it at high speeds doesnt meant it isnt causing problems...
    Get a new air filter, oil change, oil filter, spark plugs, wires, and coolant flush (just cause) and see if the problem is still there.
    iLoveSpade
  2. #2 Re: Blinking Check Engine Light
    Jul 2011
    westvirginia
    [QUOTE=Hippo Machine;636331]I'm justsaying I got my car checked out before I bought it and the mechanic said it was good. 3 weeks after, I blew the engine up. I went WOT at 80 MPH, and coolant leaked into the engine, so I guess you could say it happens only at "high speeds". AND just because you see it at high speeds doesnt meant it isnt causing problems...QUOTE] Previous owner stated he had all fluids changed, but who knows if he lied or not. Either way I think its that awful dexcool so i was planning on rad. flush soon. Ordering plugs & wires tonight, hope thats the problem -.-
    So AC delco si recommended over NGK? Or are they both about the same?
  3. #3 Re: Blinking Check Engine Light
    St. Louis
    I'm running NGK V-Power TR55's in my 00 GT and it runs fine. They are copper and I check them every time I change the oil. So far no issues. I run OEM Delco wires from my local GM dealer. Limetime warranty as long as they just wear out and not damaged by other things. I chuck them back in the box, show the receipt and they hand me a new set. They don't cost much more than any other brand even though I get them from the dealer, either.
  1. blinking Check Engine Light
    By gpgtsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2010, 06:10 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Blinking service engine soon light.
    By lutman123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 11:27 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    Last Post: 09-01-2008, 09:01 PM
