Thread: I require your vast knowledge!
Results 1 to 9 of 9
  1. #1 I require your vast knowledge!
    Sep 2011
    MI
    Just bought a 99 GTP and the guy that had it before did a few mods.
    3.3 pully
    level 1 ZZP cpu with cat delete
    3 inch down pipe
    msd wires
    fenderwall intake
    gatorback belt
    180 t-stat
    i think colder plugs
    cat and resonator gone
    and a butchered up exhaust with 3inch mufflers.
    I am adding headers when i replace trans.
    My question: Can I get away with that pully or should I get a 3.4?
    Also how much KR is absolutly too much? Obviously 0 is best but what can i get way with before it gets dangerous?
  2. #2 Re: I require your vast knowledge!
    Omaha, NE
    The link in my signature, click it and learn.
  3. #3 Re: I require your vast knowledge!
    I would pull the heads and check the tops of the pistons none of the mods listed would let you run a 3.3.
  4. #4 Re: I require your vast knowledge!
    You don't have to pull the heads to know the condition of the pistons...granted the guy prior didn't change the plugs after the pulley swap. If he didn't...yank the plugs...if the tips are gone or bent...then you have bottom end issues already.
    3.3" is too small...try a stock pulley or a 3.5"
  5. #5 Re: I require your vast knowledge!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    0 KR doesnt mean a cars always running good either. I HATE that misconception
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: I require your vast knowledge!
    Texas
    Just scan it. Then go from there.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: I require your vast knowledge!
    Sep 2011
    MI
    I'll scan it Tuesday when i'm back to work. According to the kid he just put the pully on before the transmission went.
  8. #8 Re: I require your vast knowledge!
    Sep 2011
    MI
    Quote Originally Posted by 01gpgt01 View Post
    Please explain.
  9. #9 Re: I require your vast knowledge!
    A car can have 0 KR but only be running 12* of timing. Thats not a good running car.
  1. Ignition on wire in the engine bay that wont require a relay?
    By Tengis in forum General Tech Discussion
    Last Post: 06-24-2011, 02:26 PM
  2. Need some e85 knowledge
    By GAFF in forum Off Topic Discussion
    Last Post: 11-21-2010, 08:48 PM
  3. Does CAI Require Cooler Plugs?
    By 08blackbase in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 09:15 AM
  4. Anyone have knowledge on Alero's
    By Mikefisher in forum Off Topic Discussion
    Last Post: 10-29-2008, 01:18 AM
  5. For My Knowledge Really...
    By blueguy in forum PCM Tuning
    Last Post: 09-12-2008, 12:15 AM
