Thread: Does CAI Require Cooler Plugs?
Results 1 to 3 of 3
  1. #1 Does CAI Require Cooler Plugs?
    Maryland
    I bought my '08 with 75,000 mostly highway miles. There was a little pre-ignition (part throttle up hill). It seems a little worse now that I've added a CAI (3.5" pipe, K&N filter, homemade Lexan box mated to factory air box / ECU holder).
    I just pulled the plugs. They are the factory originals and the gap is worn out to about .064". I am going to replace the wires (Autolite Professional Series #97000) and plugs (Autolite Double Platinum).
    This is a daily driver and no other engine mods are planned.
    Should I stay with the stock heat range (APP606) or go one step colder (APP605)?
  2. #2 Re: Does CAI Require Cooler Plugs?
  3. #3 Re: Does CAI Require Cooler Plugs?
    606's...you want the hottest plug you can get away with
  1. Desert fox trans cooler kit uses B&M rad?
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-21-2009, 12:53 AM
  2. Hayden trans cooler?
    Last Post: 07-16-2009, 01:04 AM
  3. bypass rad cooler?
    By _nick_ in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2008, 02:10 PM
  4. GM aux trans cooler
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:32 AM
