Thread: PERF SHIFT light?
Results 1 to 8 of 8
  1. #1 PERF SHIFT light?
    SE Level Member RichCresci's Avatar
    Jul 2008
    on my dash a have a PERF SHIFT light but its never lit up. Anyone know what its for? Thanks
    Also, one of my dash lights behind my gas gauge went out so part of my dash is darker than the rest. any clues on how to change it? thanks again.
  2. #2 Re: PERF SHIFT light?
    Apr 2008
    Chillin at the Beach , VA
    Do you have the performance shift button on the side of your shift knob? As for changing the bulb in your instrument cluster, you have to pop off the trim panel from around it. It's a pretty big peice so don't let it scare you. It will also seem like youe about to break it, but you have to pull kinda hard to get it to pop loose. A couple clips might come of and you should be able to retreive them from under the dash. There's a cover under there you can pop loose also. Once that is off, unscrew the instrument cluster and look on the backe. You should see these round looking tabs sticking out. Turn either right or left, they only turn one way, and it will slide out with the bulb stuck in it. Figure out wich bulb is blown and put everything back together.
  3. #3 Re: PERF SHIFT light?
    Jul 2008
    yeah i do, its a gtp sedan. it never lights up though. Thats what i thought i had to do but i wasnt sure. thanks. ill probably do that tomorrow.
  4. #4 Re: PERF SHIFT light?
    May 2008
    McHenry IL
    mine was the same way take your bulb out of the dumb seat belt light in the middle of the cluster and put the bulb in the spot for perf shift it lights up blue and is sweet haha good luck its easy to do =]
  5. #5 Re: PERF SHIFT light?
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by RichCresci View Post
    What year model is your car?
  6. #6 Re: PERF SHIFT light?
    Jul 2008
    1999 gtp sedan
  7. #7 Re: PERF SHIFT light?
    May 2008
    McHenry IL
    Me 2 Do Wat I Told You
  8. #8 Re: PERF SHIFT light?
    Jul 2008
    alright, thank, can i screw anything up doing this? like are thier any short wires or anything?
  1. Perf shift question.
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 08:44 PM
  2. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
  3. help... my ses light is on
    By kingd44 in forum General Tech Discussion
    Last Post: 03-07-2008, 09:45 PM
  4. srs airbag light
    Last Post: 02-03-2008, 07:46 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
