Thread: Ignition Switch Replacement Question
Results 1 to 2 of 2
Threaded View
r1rider Ignition Switch Replacement... 08-20-2010, 10:06 PM
r1rider Re: Ignition Switch... 08-21-2010, 03:27 PM
  1. #1 Ignition Switch Replacement Question
    Michigan
    My 2002 GP GT started having issues today. I heard a clicking noise under the steering wheel, the a/c stopped working, the HVAC controls no longer worked, and the daytime running lights cycled on & off. After doing a little research it seemed like the ignition switch was the likely cause.
    I replaced the ignition switch. The first time I installed the new ignition switch the car would not crank in the Crank position....but I found it would crank in the assessory position. I removed the switch and indexed the female portion of the switch that accepts the male post in the steering column 180 degrees. After reassembly I found the car cranked and ran as desired.
    My problem now is the key does not automatically return from the Crank position to the Run position. It just stays in the Crank position until I manually back it off. Did I miss something in reassembly? Everything else seems to work ok...HVAC controls & a/c work, daytime running lights no longer cycle, and blower works fine.
    Any suggestions?????
  1. ignition switch help
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 09:13 PM
  2. ignition switch
    By mtz956 in forum General Tech Discussion
    Last Post: 08-10-2010, 04:53 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. Ignition switch question
    By airhead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 09:13 AM
  5. Ignition Switch Replacement?
    By 02BlueGT in forum General Tech Discussion
    Last Post: 04-06-2008, 08:59 PM
