Thread: Any ideas? Broken coolant elbow won't come out of water pump..
Results 1 to 13 of 13
  1. #1 Any ideas? Broken coolant elbow won't come out of water pump..
    SE Level Member CRU1Z3R's Avatar
    Apr 2012
    Western, KY
    Sup guys, well today I've been really productive on my car, replaced my motor mount, replacing my back valve cover gasket and cleaned out the power steering res and put new in, and now I'm almost to the point of putting stuff back together, but I have a coolant elbow that did break off in the water pump, any ideas on how to get this piece out? Without taking the water pump off perferdly....
  2. #2 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Antioch, IL
    grab it with pliers and tug it out. Its just a plastic piece with a o ring.
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    needle nose pliers and a some wiggling?
  4. #4 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Mar 2012
    Minnesota
    ^^agreed, or if you have an awl that'll work too!
  5. #5 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Jan 2012
    Philadelphia
    that should be to hard to get out at all
  6. #6 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Apr 2012
    Western, KY
    Got all the old ends of the elbows out of the pump, LIM, and tenisoner assembly, any good suggestions about what else I need to remove, to get to the back valve cover? I started removing a bracket or two on the back side, am I really going to have to remove the fuel rail to get this damn thing off? If so how do I disconnect the fuel rails from the lines?
  7. #7 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    Sell the car! J/K fuelline removal tool usually works, they're cheap
    But why do you need to remove all that to get a coolant elbow out?
    4 out of 3 people have trouble with fractions
  8. #8 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Apr 2012
    Western, KY
    Lol this all started as a project to replace the back valve cover gasket, that tensioner has to come off its in the way...
  9. #9 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Shellman Bluff, GA
    Ahhh, I see says the blind man, the removal tool can be had at any parts store, as I said they are cheap
  10. #10 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Apr 2012
    Western, KY
    cool, I'll make my way there tomorrow, anyone know the best place to get a replacment rubber "T", the ones that sits under the snout, I found mine in 3 pieces today during the disassembly........tried at advanced auto today, no luck...figure my luck would be the same at the zone and oriely's
  11. #11 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    GT Level Member Deviq's Avatar
    SE WI
    I couldn't find just the rubber T anywhere. AZ sells rubber hoses and you have to pretty much replace the whole line to make it work, or head to the dealer and get the whole assembly for around 35.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  12. #12 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Go to the junkyard and pocket it. As far as the fuel rail go u should have plenty of slack in the lines to just lift them up and out of the way. It should reach all the way to the driver side fender. U don't have to disconnect the lines.
  13. #13 Re: Any ideas? Broken coolant elbow won't come out of water pump..
    Fuel rail and fuel line aren't in the way of the rear valve cover. If you think they are.... look again from a different angle.
    Wow..I'm fairly hung over.
  1. coolant elbow broken inside engine
    By bjlandt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2013, 09:18 AM
  2. water pump or coolant elbows?
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 12-10-2011, 03:20 AM
  3. Broken coolant hose (elbow)
    By kking89 in forum General Tech Discussion
    Last Post: 09-29-2011, 10:34 PM
  4. Need urgent help, how to get water pump elbow out
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 03:12 PM
  5. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
