Thread: Cylinder 5 misfire UPDATE Broken valve spring
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Cylinder 5 misfire UPDATE no pressure in cyl
    Acworth, Georgia
    broken spring
  2. #22 Re: Cylinder 5 misfire UPDATE no pressure in cyl
    that will do it...
  3. #23 Re: Cylinder 5 misfire UPDATE no pressure in cyl
    Acworth, Georgia
    So can I just change that one spring or will I need to do them all?
  4. #24 Re: Cylinder 5 misfire UPDATE no pressure in cyl
    Portland Oregon
    How does the spark plug from that cylinder look? Bent, broken, anything? If the spark if is fine then your piston is still there and points to valvetrain
  5. #25 Re: Cylinder 5 misfire UPDATE Broken valve spring
    yes you can just change the one spring, but do check the plug, if its damaged, you have bigger problems like stated above.
  6. #26 Re: Cylinder 5 misfire UPDATE Broken valve spring
    Acworth, Georgia
    All the plugs are good. I need to go to the dealership tomorrow and get one. No autoparts stores around carry it in stock.
  7. #27 Re: Cylinder 5 misfire UPDATE Broken valve spring
    I'd get a borescope and check the piston....but that's me
  1. Cylinder #3 misfire
    By redgtp97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2013, 04:08 PM
  2. Misfire in Cylinder 5
    By 06gtSC in forum General Tech Discussion
    Last Post: 04-19-2011, 03:50 PM
  3. cylinder one misfire
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2010, 03:48 PM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
