Thread: Removing Alternator Pulley
Results 1 to 3 of 3
  1. #1 Removing Alternator Pulley
    SE Level Member Spaceghost's Avatar
    Aug 2011
    Gibsonia, PA
    There looks to be a torx bit opening on the end of the alternator spindle and then a bug nut that holds the stock pulley on there. Is the general method of removing the alternator pulley to hold the spindle in place while turning the nut off?
    Any idea what size torx bit that is? Is there another manner by which people remove the pulley?
    L32 SB, P&P SC, Ported LIM, ZZP Headers, North*, LQ4, 180 Thermo, DHP V 1.0, Borla, UD H2O, Poly MM, 17's, Sony's, STB, 1.9's, 3.4, JMB w/ K&N
  2. #2 Re: Removing Alternator Pulley
    Zap the nut with an impact while holding the pulley edge.
    Or you'd need that torx and a wrench.
  3. #3 Re: Removing Alternator Pulley
    Aug 2011
    Gibsonia, PA
    I'll have to use the torx and the wrench then because I don;t have access to an impact gun.
  1. Removing Gen V Stock Pulley
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 09:40 PM
  2. Removing Crank Pulley
    By Poil336 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 12:57 PM
  3. Removing alternator housing
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 06:14 PM
