My odometer and what tells me what gear Im in doesnt light up anymore? It started over a week. When I would press the trip meter a million times it would come back on now is just dead. Everything else lights up fine. Any ideas? No its not a fuse lol
It's probably the bulb. Take the cluster out and take a look.
Sylvania has a bulb finder, this is what came up for a 98 GP Instrument Panel:
Instrument-general
194
194ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
37
37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
PC195
PC74
Based on that, it SHOULD be a single bulb to pop out and replace.
Wait....are you talking about the odometer on your Regal? Or on a grand prix?
This is the back of the cluster of a grand prix. The circle is where the odometer bulbs are located. (unfortunately theyre not just twist outs like the rest of them)
heres a vid how to fix the cluster for a regal How-to fix a 97.5-2004 buick regal gauge cluster - YouTube
mine was out when i got mine, i sent it to a ebay cluster repair guy, and mine was already repaired by someone who couldn't solder and my board was dead. so the guy was able to d/l my info, aka mileage, and put it into another cluster, but it was for a newer year and 1/2 my gauges did not work, so he had to find one that was from a 98 , same as my car, (a 98) that he rebuilt and sent, cost 100 bucks but like i said the board was all f'ed up.
if you can solder a board i say give it a shot.
to remove the cluster is easy, the trim piece across the dash needs to come off, take the sides off first, fuse cover,same for driver side, then you will see the clips for the trim, pop it out on the pass side first, and just keep popping the clips, (oh it helps to pull the center dash out a bit, 2 clips top corners, where it goes around the climate control) when you get to the part in front of you where the cluster is tilt the wheel down, and pull the bottom out, and slide it out.
the air vents stay in the trim piece too, so dont worry when you see them coming out with it. this is a good time to pop them out and clean them too.
the cluster its self is 4 small screws 4 corners, pull the bottom out and flip it up, the plug is on the top middle of the cluster, you will have plenty of extra harness to play with the plug to get it off. it is a tight fit, even after you un clip it.
And I offically feel like a dumbass.......... Those side fuse covers that get popped off first just didnt want to budge. Next time they get a little more umph
