Thread: Odometer doesnt light up?
Results 1 to 20 of 22
  1. #1 Odometer doesnt light up?
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    My odometer and what tells me what gear Im in doesnt light up anymore? It started over a week. When I would press the trip meter a million times it would come back on now is just dead. Everything else lights up fine. Any ideas? No its not a fuse lol
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Odometer doesnt light up?
    Omaha, NE
    It's probably the bulb. Take the cluster out and take a look.
  3. #3 Re: Odometer doesnt light up?
    Oct 2008
    IL
    It seems like it would be now of a led setup on a board? Is it easy removal. My old s10 sucked thats why I ask
  4. #4 Re: Odometer doesnt light up?
    Omaha, NE
    Sylvania has a bulb finder, this is what came up for a 98 GP Instrument Panel:
    Instrument-general
    194
    194ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
    194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    37
    37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    PC195
    PC74
    Based on that, it SHOULD be a single bulb to pop out and replace.
  5. #5 Re: Odometer doesnt light up?
    Oct 2008
    IL
    Instrument-general
    194
    37
    PC195
    PC74
    Ok Ok you win. Lol now Just to take this thing out. Thanks Ill give this a shot. I just read a writup from Billyboost and it could be resistor too. It was cutting in and out didnt just go out.
  6. #6 Re: Odometer doesnt light up?
    Houston
    The odometer bulb is covered, you'll have to take apart the odometer case.
  7. #7 Re: Odometer doesnt light up?
    Oct 2008
    IL
    If I just got a new cluster would it still have the same Mileage? My experince with any form of computer boards is always a bad experience
  8. #8 Re: Odometer doesnt light up?
    Houston
    Wait....are you talking about the odometer on your Regal? Or on a grand prix?
    This is the back of the cluster of a grand prix. The circle is where the odometer bulbs are located. (unfortunately theyre not just twist outs like the rest of them)
  9. #9 Re: Odometer doesnt light up?
    heres a vid how to fix the cluster for a regal How-to fix a 97.5-2004 buick regal gauge cluster - YouTube
    mine was out when i got mine, i sent it to a ebay cluster repair guy, and mine was already repaired by someone who couldn't solder and my board was dead. so the guy was able to d/l my info, aka mileage, and put it into another cluster, but it was for a newer year and 1/2 my gauges did not work, so he had to find one that was from a 98 , same as my car, (a 98) that he rebuilt and sent, cost 100 bucks but like i said the board was all f'ed up.
    if you can solder a board i say give it a shot.
  10. #10 Re: Odometer doesnt light up?
    Oct 2008
    IL
    This is for my Regal. Im just trying to figure out how to start to get this thing out without breaking ****.
    Yea Ill end up having the R&D guys at work do the sodering if I ever get this thing out.
  11. #11 Re: Odometer doesnt light up?
    to remove the cluster is easy, the trim piece across the dash needs to come off, take the sides off first, fuse cover,same for driver side, then you will see the clips for the trim, pop it out on the pass side first, and just keep popping the clips, (oh it helps to pull the center dash out a bit, 2 clips top corners, where it goes around the climate control) when you get to the part in front of you where the cluster is tilt the wheel down, and pull the bottom out, and slide it out.
    the air vents stay in the trim piece too, so dont worry when you see them coming out with it. this is a good time to pop them out and clean them too.
    the cluster its self is 4 small screws 4 corners, pull the bottom out and flip it up, the plug is on the top middle of the cluster, you will have plenty of extra harness to play with the plug to get it off. it is a tight fit, even after you un clip it.
  12. #12 Re: Odometer doesnt light up?
    Oct 2008
    IL
    Wow thanx for the descriptive writeup. I hate not knowing my mileage
  13. #13 Re: Odometer doesnt light up?
    Quote Originally Posted by chevyy1212 View Post
    np i've had mine off 4 or 5 times already.
    my title said 160,000 at last owner, when the guy called me and told me it was 212,000 i almost fell over. so my lights were out for years and years till i had it fixed. my climate control chips have been re soldered too, had no lights there either.
  14. #14 Re: Odometer doesnt light up?
    Oct 2008
    IL
    Wow that really makes me hope my miles are correct then. My carfax tho lines up prefect with the miles I had and it didnt stop workin till about 4 months after I bought it. Man you just made my stomach drop.
  15. #15 Re: Odometer doesnt light up?
    your mileage is ok, yours went out while you had it.
    mine was out for a few owners i think, the last owner titled at 160,000 and only a had the car for a year, and i got it at 212,000, so that don't add up. im the 8 th owner too.
  16. #16 Re: Odometer doesnt light up?
    Oct 2008
    IL
    Wow your the 8th owner thats crazy!!! Im the second owner. Like I said my carfax all adds up perfectly tho. I got it from some dealer in the city that was loaded with BMWs and Benzs and there was this random Regal lol. They didnt even know it was supercharged. The s/c wasnt even hooked up actually I made them hook it up before I would buy it. Only downfall is its got some doordings small but there from being a 13 yearold city car
  17. #17 Re: Odometer doesnt light up?
    It's easy.
  18. #18 Re: Odometer doesnt light up?
    Oct 2008
    IL
    It's easy.
    Lol well when I figure out how how to get this dash off I hope it will be as easy as you say. I trie to pop the 2 side panels off to be able to pull that full front trim piece off that has the vents on it BUT the side panels seem to not come off and I take it those need to come off to get that front black trim off
  19. #19 Re: Odometer doesnt light up?
    i knew i saw this some where, here ya go.regal dash removal - YouTube
  20. #20 Re: Odometer doesnt light up?
    Oct 2008
    IL
    Now I am set
  1. D.I.C doesnt light up
    By gpgt98 in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2010, 05:03 PM
  2. odometer reading/DIC
    By rodburner in forum General Tech Discussion
    Last Post: 06-02-2010, 09:15 PM
  3. crazy speed odometer
    By rharper33 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 04:38 PM
