Thread: Odometer doesnt light up?
Results 1 to 20 of 22
chevyy1212 Odometer doesnt light up? 08-14-2011, 02:35 PM
Explicit_Spade Re: Odometer doesnt light up? 08-14-2011, 02:40 PM
chevyy1212 Re: Odometer doesnt light up? 08-14-2011, 02:43 PM
Explicit_Spade Re: Odometer doesnt light up? 08-14-2011, 02:48 PM
chevyy1212 Re: Odometer doesnt light up? 08-14-2011, 02:56 PM
KeithGTP03 Re: Odometer doesnt light up? 08-14-2011, 02:56 PM
chevyy1212 Re: Odometer doesnt light up? 08-14-2011, 03:03 PM
KeithGTP03 Re: Odometer doesnt light up? 08-14-2011, 03:10 PM
Scottydoggs Re: Odometer doesnt light up? 08-14-2011, 03:28 PM
chevyy1212 Re: Odometer doesnt light up? 08-14-2011, 04:59 PM
Scottydoggs Re: Odometer doesnt light up? 08-14-2011, 05:14 PM
chevyy1212 Re: Odometer doesnt light up? 08-14-2011, 07:39 PM
Scottydoggs Re: Odometer doesnt light up? 08-14-2011, 07:45 PM
chevyy1212 Re: Odometer doesnt light up? 08-14-2011, 10:03 PM
Scottydoggs Re: Odometer doesnt light up? 08-14-2011, 10:09 PM
chevyy1212 Re: Odometer doesnt light up? 08-15-2011, 09:42 AM
chevyy1212 Re: Odometer doesnt light up? 08-15-2011, 10:58 PM
BillBoost37 Re: Odometer doesnt light up? 08-16-2011, 05:39 AM
  1. #1 Re: Odometer doesnt light up?
    to remove the cluster is easy, the trim piece across the dash needs to come off, take the sides off first, fuse cover,same for driver side, then you will see the clips for the trim, pop it out on the pass side first, and just keep popping the clips, (oh it helps to pull the center dash out a bit, 2 clips top corners, where it goes around the climate control) when you get to the part in front of you where the cluster is tilt the wheel down, and pull the bottom out, and slide it out.
    the air vents stay in the trim piece too, so dont worry when you see them coming out with it. this is a good time to pop them out and clean them too.
    the cluster its self is 4 small screws 4 corners, pull the bottom out and flip it up, the plug is on the top middle of the cluster, you will have plenty of extra harness to play with the plug to get it off. it is a tight fit, even after you un clip it.
  2. #2 Re: Odometer doesnt light up?
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Wow thanx for the descriptive writeup. I hate not knowing my mileage
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  3. #3 Re: Odometer doesnt light up?
    Quote Originally Posted by chevyy1212 View Post
    np i've had mine off 4 or 5 times already.
    my title said 160,000 at last owner, when the guy called me and told me it was 212,000 i almost fell over. so my lights were out for years and years till i had it fixed. my climate control chips have been re soldered too, had no lights there either.
  4. #4 Re: Odometer doesnt light up?
    Oct 2008
    IL
    Wow that really makes me hope my miles are correct then. My carfax tho lines up prefect with the miles I had and it didnt stop workin till about 4 months after I bought it. Man you just made my stomach drop.
  5. #5 Re: Odometer doesnt light up?
    your mileage is ok, yours went out while you had it.
    mine was out for a few owners i think, the last owner titled at 160,000 and only a had the car for a year, and i got it at 212,000, so that don't add up. im the 8 th owner too.
  6. #6 Re: Odometer doesnt light up?
    Oct 2008
    IL
    Wow your the 8th owner thats crazy!!! Im the second owner. Like I said my carfax all adds up perfectly tho. I got it from some dealer in the city that was loaded with BMWs and Benzs and there was this random Regal lol. They didnt even know it was supercharged. The s/c wasnt even hooked up actually I made them hook it up before I would buy it. Only downfall is its got some doordings small but there from being a 13 yearold city car
  7. #7 Re: Odometer doesnt light up?
    It's easy.
  1. D.I.C doesnt light up
    By gpgt98 in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2010, 05:03 PM
  2. odometer reading/DIC
    By rodburner in forum General Tech Discussion
    Last Post: 06-02-2010, 09:15 PM
  3. crazy speed odometer
    By rharper33 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 04:38 PM
