Thread: WTF, Car will only shift between N and D now!
Results 1 to 7 of 7
  1. #1 WTF, Car will only shift between N and D now!
    Windsor (ON) Canada
    First off, I've did some searching and I've mostly found cars not being able to shift OUT of park. "Not sure if it's the same problem just reversed" But anyways, two days ago I tried to put the car INTO Park it was not happening!! I could shift into (1,2,3,D,N and R) but no park, was fine for a day until tonight, now I can only shift between D and N. The car is currently in the driveway (in Neutral) with the emergency brake on a wheel chock. I had to use a pen to push the botton under the steering wheel to get the key out.
    Can anyone walk me through what the hell I'm supposed to fix, of is there a cheapo way to fix this (like zip tie something down???)
  2. #2 Re: WTF, Car will only shift between N and D now!
    Windsor (ON) Canada
    Anyone!!??
  3. #3 Re: WTF, Car will only shift between N and D now!
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hows your shift cable look? the cable that goes from the shifter to the transmission..
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: WTF, Car will only shift between N and D now!
    SE Level Member Spaceghost's Avatar
    Aug 2011
    Gibsonia, PA
    How loose is your shifter handle? Sometimes if it pops up slightly you cannot get the car into park. Smack it down a bit and see what happens. This happened to me once and was due to the shifter knob itself being shifted upward.
    L32 SB, P&P SC, Ported LIM, ZZP Headers, North*, LQ4, 180 Thermo, DHP V 1.0, Borla, UD H2O, Poly MM, 17's, Sony's, STB, 1.9's, 3.4, JMB w/ K&N
  5. #5 Re: WTF, Car will only shift between N and D now!
    remove the cable from the trans and then try to move the sifter. see what moves.
  6. #6 Re: WTF, Car will only shift between N and D now!
    Windsor (ON) Canada
    Quote Originally Posted by Spaceghost View Post
    Took the center console apart today and checked everything out, besides tons of dirt, everything looked good. Pressed the plastic shifter "button" and was able to shift into park, im thinking my shift knob did infact shift up slighty and was not able to push the shift button down fully.
    Thanks everyone
  7. #7 Re: WTF, Car will only shift between N and D now!
    Aug 2011
    Gibsonia, PA
    Knew it. Glad you worked it out.
  1. shift kit
    By offroadfury6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 10:11 AM
  2. shift kit
    By Nos shottss in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2009, 05:12 PM
  3. Tap Shift???
    Last Post: 09-21-2008, 09:43 PM
