Thread: Currently Running 3.4 Pulley - Want to go 3.3
Results 1 to 20 of 21
  1. #1 Currently Running 3.4 Pulley - Want to go 3.3
    SE Level Member Spaceghost's Avatar
    Aug 2011
    Gibsonia, PA
    So my mods are the following:
    2004 L32 Short Block with L67 Lower Intake Manifold and Gen III M90
    Self Ported Lower Intake Manifold
    Self Ported and polished supercharger. Inlet Ported to 75mm.
    ZZ Performance Improved Supercharger Coupler
    Thrasher 3.4” Press On
    W-Body Store 75mm Cadillac Northstar Throttle Body
    W-Body Store 85mm LQ4 Mass Air Flow Unit
    JMB Cold Air Intake 4” Diameter
    K&N 4” X 7” Cone Filter in Fenderwell
    ZZ Performance Modified 1.9 Ratio Rocker Arms
    ZZ Performance Stainless Steel Long Tube Headers
    ZZ Performance 3” Downpipe with U-Bend Delete
    Magnaflow Catalytic Converter
    Borla Stainless Steel Exhaust
    ZZ Performance O2 Simulator at Cat
    Digital Horsepower v1.0 PCM
    ZZ Performance Shift Kit Switch & Wire
    Hydrostat 180 Degree Thermostat
    Smoothflow Underdrive Water Pump Pulley
    Autolite 103 and 104 Colder Plugs
    Custom Tuning Performed by Dave Richie, Lititz, PA
    W Body Store Poly Motor Mounts
    I will be changing over to a higher flow fuel filter and going with either AL 103 or NGK TR8 plugs. PRJ Wires and I only run 93 octane.
    Can I change my 3.4 over to a 3.3 without creating a ton of knock?
    L32 SB, P&P SC, Ported LIM, ZZP Headers, North*, LQ4, 180 Thermo, DHP V 1.0, Borla, UD H2O, Poly MM, 17's, Sony's, STB, 1.9's, 3.4, JMB w/ K&N
  2. #2 Re: Currently Running 3.4 Pulley - Want to go 3.3
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Im sure everyone is going to tell you the only way to truley know is try and then scan. Every car is different. If you have no issues now the best thing to do is give it a whirl. However, if you have ANY knock now I wouldnt even attempt it
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Aug 2011
    Gibsonia, PA
    Hmm....I did get 2-3 degrees of knock before the ported blower, ported LIM, Upper Poly MM's, and UD H2O pulley not that the pulley would reduce any knock.
  4. #4 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Grand Island, Nebraska
    So N*, ported blower, zzp headers, 1.9's, intake.
    I'd say yes, but you still should scan.
  5. #5 Re: Currently Running 3.4 Pulley - Want to go 3.3
    For the gains, which won't be noticiable really...a tenth of an inch isn't worth it. I'd also...at this point tell you...why haven't you bought a modular pulley system? Press-on's are weaksauce
    Just get it tuned for more timing.
    More timing lower/boost is faster than lower timing/high boost...
    Another thing...sell that JMB and toss an open cone on the end of the LQ4 MAF sensor...and put some AL104's in your car...103's are way too cold...you want the hottest spark possible, not the coldest.
  6. #6 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Aug 2011
    Gibsonia, PA
    Right now I have 104's in the car. I was just reading that ZZP prefers 103's so i though about giving them a whirl. I kept the press on because I thought I wanted a 3.4 setup when I changed out the 3.8. Now, I feel like i want to go smaller but I hear ya. Maybe I should look into more timing instead.
  7. #7 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Click the link in my signature if you haven't.
    ZZP is FULL of misinformation, old...outdated stuff that isn't the correct path to take, nor gives the best explanation possible for your car.
  8. #8 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Aug 2011
    Gibsonia, PA
    Yup, that's what i figured. THanks.
  9. #9 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Nov 2010
    Baltimore
    You are perfectly set up for a ssic. I know most will say go full size, but if you're content with nothing smaller than a 3.2 than a ssic is for you. I went from a 3.4 to 3.25 with one and am currently kr free. With your mods u might be able to get away with a 3.1, wouldn't hurt to try. If u have a scanner that is.
  10. #10 Re: Currently Running 3.4 Pulley - Want to go 3.3
    I would probably hurt to try...since most factory injectors run static at a 3.2"...also...we will say that an SSIC is a waste because it really is.
    For not much more money...he could get a full size core...and snag up some 42.5lb. injectors and run a 2.6/2.8.
    Which is what I would do...I wouldn't waste my time with an SSIC, IMO.
  11. #11 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Nov 2010
    Baltimore
    nevermind.
  12. #12 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Jul 2010
    Michigan
    Quote Originally Posted by CBWhite View Post
    What do u mean "you wouldn't waste your time on a ssic." I'm not talking to u asshole, i'm talking to him. I'm giving him advice not you. So stfu. Just becausec u have a full size and it works perfectly BIG DEAL! A fullsize intercooler is not for everyone. So stfu! A 2.6 0r 2.8? What! Most people don't want to run anything anywhere near that small a pulley. Everyone doesn't see things the way u do.
    Berating a mod is a horrible idea first off....
    Second he is giving this guy his .02... he was telling him he could pretty much get a better IC for the same cost.. I dont see where he was doing antything bad. Getting opinions is what this guy asked for and he was giving his opinion to attack him based on this is just silly....
    2005 GTP Grey
  13. #13 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Aug 2011
    Gibsonia, PA
    Keep it clean guys. My question is whether with my current mods could I drop to a 3.3 and tune using HP Tuners to reduce knock and increase timing. That's the opinion I am asking for. Thanks all.
  14. #14 Re: Currently Running 3.4 Pulley - Want to go 3.3
    To go 1/10" smaller will not make any difference really.
    And with going Intercooled, whether Full size or Short stack, you will have to tune for it to be beneficial ultimately.
    Lastly, Full size's can be had for the cost of SSIC these days anyways, so if you do decide to do it, take that into consideration.
    And one more though, with added power, you really have to consider what condition your tranny will be in. Most say that 300whp mark is the point where a completely stock tranny will begin to show its weak points.
  15. #15 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    yes you can drop but you are better off keeping a bigger pully with more timing and no knock the a smaller pully with less timing if u wanna drop pully save your money and buy a ic keep your eye on the classifieds u can find them cheap then drop to a 3.2 or upgrade your injectors and run a 3.0 just my 0.02
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  16. #16 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Akron Ohio
    Wow 17 posts and all ready acting like an asshat! You scare me internet MAN!
  17. #17 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Aug 2011
    Gibsonia, PA
    How about this. Lower timing on a 3.2 pulley instead of a 3.3 without an IC or a cam?? It's been done. There are quite a few cars that I know of that run a 3.2 without either and claim low to no KR.
  18. #18 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Many tuners have found that you get more power from timing than boost. Therefore typically it's viewed that staying with a larger pulley to keep the cylinder and air charge temps down with higher timing works better.
    Pulley envy is simply that. As is boost pressure. High boost numbers only means that ther is a restriction between the blower and the tail pipes. In your case the biggest restriction would be the ability to process flow through the heads. Boost is read from the LIM. The higher the number, the more pressure is built up and being held in the LIM.
  19. #19 Re: Currently Running 3.4 Pulley - Want to go 3.3
    thank you bill
    sold 97 GTP stock
  20. #20 Re: Currently Running 3.4 Pulley - Want to go 3.3
    Quote Originally Posted by Spaceghost View Post
    Probably because they are running stock 16*....if not lower than stock to get away with a smaller pulley...or pig rich to prevent the knock. I'd like to see those bin files.
    There are also side effects of lower timing...higher EGT's being the main one, higher EGT's, higher temps in the motor from more boost on the smaller pulley = not a happy 3800
    I'd honestly...like I said before...keep the 3.4"...and timing the crap out of it...see how much you can get away with. I'd bet it would run like a raped ape on 20-22*
  1. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  2. How Long Have You Been Running A Smaller Pulley?
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 09:13 AM
  3. running a 3.25" pulley
    By CompCam21 in forum General Tech Discussion
    Last Post: 01-30-2010, 05:33 PM
