Thread: Emergency, stuck and need help
Results 1 to 13 of 13
  1. #1 Re: Emergency, stuck and need help
    Texas
    Not worth the risk driving IMO. I would just change the oil in the parking lot. Don't worry about the filter ATM.
    85 Corvette
    01 TA
    03 Z06
  2. #2 Re: Emergency, stuck and need help
    Pennsylvania
    Ok well I got it home and started it, no milkshake or anything... the oil looks good on the stick and in the filler hole.
    But my main question is wtf, why did those bolts get so loose in the first place? It was only the ones by the tb that came loose, it seems like the rest of them stuck.. and why did it run fine for 2 days and suddenly I go to leave work and this happens...
    Sport Edition Kv5 18x8
  3. #3 Re: Emergency, stuck and need help
    What did you torque the bolts to? They are supposed to be something like 89in lbs.
    As for coolant in the oil. It's not likely that you got any in there if much. Because it would have had to get past the piston rings.
  4. #4 Re: Emergency, stuck and need help
    Um the Bolt size and torque thread says 11ft lbs, and 89in lbs is only 7.4ft lbs. The throttle body is 89in lbs though. Im pretty sure you were just trying to remember the number off the top of your head and just said the wrong one it happens.
  5. #5 Re: Emergency, stuck and need help
    Quote Originally Posted by slick2500 View Post
    Upper plenum 89in.lb. (7.5 lb. ft.)
    ^^^ I'm pretty sure that says 89in lbs. Had lasik done about 2 years back and my yearly checkup showed me as 20/20.
    The OP is taliing about the UIM or upper intake aka plenum. The 11ft lbs, on the LIM is actually incorrect and I'll chat with TON about it because I have some different ideas about where it should be vs where GM said it should be based on the gasket revisions.
    For giggles, if you happen to look at a 97 Bonneville FSM the torques are reversed for the LIM and UIM. UIM is listed as 13ft lbs (per fsm) and LIM is listed as 89 inch lbs. All FSM's I've looked up for this spec were 13ft lbs on the lim and 89 inch lbs on the UIM except that 97 Bonne.
  6. #6 Re: Emergency, stuck and need help
    Kansas
    Quote Originally Posted by txslow6 View Post
    This.
    I would rather pay 15-20 bucks for an oil change over a short block replacement. Even if I had the slightest doubt in my mind that there was coolant in the oil.
  7. #7 Re: Emergency, stuck and need help
    How does the coolant get in the oil guys?
    You'd hydrolock before you had enough coolant in the cylinder to push past the rings.
  8. #8 Re: Emergency, stuck and need help
    Pennsylvania
    I tightened them down until they were hard to move further, plus a little... that seems to be what everyone else does and they didnt have this problem as far as I know... I asked 2 people and they did the same as I did :\.
    It seems like it was only the really long bolt that goes through the tb and the one that goes in near the egr that came loose, the ones I can reach with the fuel rail still attached were still solid and dry
    I guess I should see if anyone has a torque wrench I could borrow...
  9. #9 Re: Emergency, stuck and need help
    Kansas
    Quote Originally Posted by FriboRage View Post
    Maybe your just a weakling, or maybe your super strong and stripped the holes with your overpowering skills. In all reality, my post is showing how bored I am.
  1. Emergency brake gone
    By BlackJack in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 08:49 PM
  2. emergency help needed. Stuck. Car is surging and stalling
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 12:10 PM
