Thread: Hard to start
Results 1 to 5 of 5
  1. #1 Hard to start
    May 2008
    Since yesterday my 2000 GTP has gotten more and more difficult to start. When I turn the ignition and hold it, the lights dim a little, it waits a few seconds, then the starter comes on, and it starts right up. This has gone from yesterday afternoon where the hesitation was maybe a second, to today where it's taking longer and longer each time, and currently at maybe 5-6 seconds. Is the starter going bad, or should I be looking somewhere else? The battery was also replaced less than a month ago. Is it possible I got a bad one?
    Thanks,
    Steve
  2. #2 Re: Hard to start
    St. Louis
    How do the cables look at the battery and the ground points? I had this happen on my GT and the connections at the battery were corroded and loose. Make sure they're clean and tight and go from there.
  3. #3 Re: Hard to start
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Have your battery tested and check your battery connections.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  4. #4 Re: Hard to start
    Charles City, IA
    yeah check the battery, could also be the starter going bad.
    SMGPFC Two Nipple General
  5. #5 Re: Hard to start
    May 2008
    Thanks for the help all. It ended up being the starter. Swapped it out, and everything started working just fine. Well as fine as all of the various other issues with it let it be.
  1. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  2. hard start
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 12:43 AM
  3. unpredictable hard start.
    By Teardrop in forum General Tech Discussion
    Last Post: 11-08-2010, 02:47 PM
  4. Car hard to start.
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 11:44 AM
  5. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
