Thread: Short laundry list from last inspection
Results 1 to 5 of 5
  1. #1 Short laundry list from last inspection
    Donating Users
    I just switched to a new-to-me mechanic in town and I got a short list of things that need attending to in the relatively near future, and I'm looking for more experienced advice on which should be prioritized the highest.
    First off, I switched shops because the last one apparently mixed green antifreeze with the existing Dexcool during a "courtesy check of fluids" when the car was in for unrelated service (tires). I found the sludge in the overflow and figured that shop just lost a customer, and now was as good a time as any to get a thorough chemical flush and switch to green. While the guy was in there here's the big stuff he found:
    Leaking oil pan gasket (no surprise, but still not great)
    Cracked serpentine belt (for the supercharger etc.; other belt is fine)
    Seeping axles (not dripping, but wet)
    Which of these would you place the highest priority on addressing?
    Good news is no coolant in the oil or vice-versa, and the cooling system isn't damaged since I caught the snafu in time.
  2. #2 Re: Short laundry list from last inspection
    Charles City, IA
    axles loosing grease? or axle seals leaking trans fluid?
    SMGPFC Two Nipple General
  3. #3 Re: Short laundry list from last inspection
    replace the belt, takes like 2 min.
  4. #4 Re: Short laundry list from last inspection
    Donating Users
    Axle seals losing trans fluid as far as I understood him, but he didn't say specifically. He didn't sound concerned, just mentioned I should be aware.
  5. #5 Re: Short laundry list from last inspection
    Charles City, IA
    None of that is going to leave you sitting. I would go belt, axle seals, then oil pan gasket. Thats going from cheapest to most expensive.
  1. i passed inspection
    By Scottydoggs in forum Off Topic Discussion
    Last Post: 06-17-2011, 09:50 AM
  2. inspection problem
    By kingd44 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2011, 08:17 PM
  3. passed inspection with a smokey car
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2009, 08:30 AM
  4. Passing Inspection
    By blueguy in forum General Tech Discussion
    Last Post: 02-22-2009, 11:52 PM
  5. Help with a Pennsylvania Inspection
    By JoshMcMadMac in forum Off Topic Discussion
    Last Post: 12-24-2008, 11:36 AM
