Thread: Need Help with fuel pump removal
Results 1 to 6 of 6
abuckley1290 Need Help with fuel pump... 01-24-2010, 03:31 PM
abuckley1290 Re: Need Help with fuel pump... 01-24-2010, 09:01 PM
Pittman06 Re: Need Help with fuel pump... 01-24-2010, 09:11 PM
abuckley1290 Re: Need Help with fuel pump... 01-24-2010, 09:19 PM
BillBoost37 Re: Need Help with fuel pump... 08-11-2011, 01:19 PM
FoSHO99 Re: Need Help with fuel pump... 08-11-2011, 04:51 PM
  1. #1 Need Help with fuel pump removal
    SE Level Member abuckley1290's Avatar
    Jul 2008
    I cannot locate the snap ring on my fuel pump. I can only find directions for cars older than 2000, so i am guessing maybe my 2002 is different?
    40th Anniversary GP
  2. #2 Re: Need Help with fuel pump removal
    Jul 2008
    40th Anniversary GP
  3. #3 Re: Need Help with fuel pump removal
    Wooster, Ohio
    what snap ring? the outter ring spins, normally with a flathead and a small hammer and tapping it counter clockwise
  4. #4 Re: Need Help with fuel pump removal
    Jul 2008
    thats what i thought but all the how to's said theres a snap ring. thanks ill give that a shot
    40th Anniversary GP
  5. #5 Re: Need Help with fuel pump removal
    That pump does look different.
    Here is what we are used to seeing.
    Here's the ring
  6. #6 Re: Need Help with fuel pump removal
    Jan 1970
    Maquoketa, Iowa
    2001+ plastic tanks don't have a "snap ring"
    That rusted out 2" think ring is what holds the canister in.
    With a flathead and rubber hammer like said above, it will come out. Those metal tabs sticking up (yellow lines) have a groove shape on the end of them holding the whole ring in place. Just pound and don't break anything. That black connector on top, next to the white, will wiggle straight up out of there if you want to get it out of the way.
    Another thing to note is the style of canister/bucket is different in 01+ than 97-00. 01+ has no venturi, so if you have a new fuel pump that has a port on the top of it next to the electrical connector, that is for venturi feed to the pump and is the wrong pump.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Help 2001 Grand Prix water pump removal
    By prosecho in forum General Tech Discussion
    Last Post: 09-12-2009, 09:47 PM
  3. Fuel pump??
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:25 AM
  4. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
