Thread: Engine Is FINALLY Built! Added Pics!
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 Engine Is FINALLY Built! Added Pics!
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    L32 Shortblock
    MP112
    INTENSE Intercooler
    INTENSE Ported Lower Intake Manifold
    INTENSE Stage 4 heads
    INTENSE Stage 3 cam
    Yella Terra 1.7 Roller Roclers
    LS1 Throttle Body
    INTENSE 3/8" Pushrods
    Comp Cams OE-R Lifters
    INTENSE Oil Relocation Kit
    Meziere Electric Water pump
    ATI 8 Rib Harmonic Balancer
    Cometic Head Gaskets
    ARP Head Studs
    Balance Shaft Removed
    Rollmaster Double Roller Timing Chain
  2. #2 Re: Engine Is FINALLY Built
    Feb 2008
    Holy chit! That is beautiful!!
    Since you don't have it in yet, I'll be more than happy to try it out in my car for you...
    Just out of curiosity, what's the benefit of removing the balance shaft? Is it just a weight thing?
  3. #3 Re: Engine Is FINALLY Built
    Las Cruces, NM
    Thank you!
    It gets disabled when running a double roller. The gears to turn it are in the way. With the engine out of the car its pretty safe and easy to remove it and plug the rear oil feed to it.
  4. #4 Re: Engine Is FINALLY Built
    chicago
    i'm not very familar with the MP112 blower, but what's the big diffence than the M90? also from what year does the 'stang that came with Mp112?
  5. #5 Re: Engine Is FINALLY Built
    Hoffman/Schaumburg, IL
    2001 -2003 cobra and some years of lightning if I remember correctly...... Sweet car, those MP112s' scream in the cobras, gonna sound obscene in a GP
  6. #6 Re: Engine Is FINALLY Built
    I live here. UR LOSN's Avatar
    Rockford, IL
    Way back when those were labeled as Strip only blowers......
    by the looks of that motor..... I would say that is what it will be used for..lol
    I wonder how long it will take for you to snap an axle! we need to put a poll up.
    Motor looks awesome!!!!!
    EDIT: Stock Flexplate? your not going with an aftermarket once piece?
  7. #7 Re: Engine Is FINALLY Built
    Las Cruces, NM
    The Mustangs and Lightning use the M112 blower. Same rotors but completely different housing. These were custom made by Magnesun and are 22cc larget then the M90 and it's a gen V so it has all the upgrade bonuses that the M90 has.
    I'm hoping to loose traction before anything breaks, including axles. I'm only going to run GM units though if they do break.
    This actually is going to be a strip "sometimes" car but it's not my DD either, just an expensive toy.
  8. #8 Re: Engine Is FINALLY Built
    Las Cruces, NM
    Yes stock until it cracks the first time. The ATI balancer is "supposed" to absorb the flexplate craking vibration.
  9. #9 Re: Engine Is FINALLY Built
    Las Cruces, NM
    Added a set of Gen 3 PRJ Rails today:
  10. #10 Re: Engine Is FINALLY Built! Added Pics!
    Las Cruces, NM
    One last angle:
  11. #11 Re: Engine Is FINALLY Built! Added Pics!
    Apr 2008
    Chillin at the Beach , VA
    That thing is beautiful!!! Is it going to fit under the hood?
  12. #12 Re: Engine Is FINALLY Built! Added Pics!
    Moore, Oklahoma
    Wow looks good, thats going to be a fun toy!
    Shawn W. Larsen
  13. #13 Re: Engine Is FINALLY Built! Added Pics!
    Las Cruces, NM
    Suprisingly it does fit under a stock hood.
  14. #14 Re: Engine Is FINALLY Built! Added Pics!
    Apr 2008
    That's good. Can't wait to see it in the car. Is there going to be any videos after the install?
  15. #15 Re: Engine Is FINALLY Built! Added Pics!
    Las Cruces, NM
    I'll be sure to take videos of the dyno and the track.
  16. #16 Re: Engine Is FINALLY Built! Added Pics!
    TDCRacing
    Guest
    explain to me the differences of your mp112 vs. a stock one off of a mustang. sorry i didnt get it the first time
  17. #17 Re: Engine Is FINALLY Built! Added Pics!
    Las Cruces, NM
    The M112 is a OEM Eaton blower. It wont work without serious machine work. The inlet is facing the wrong way and the bottom of it would be a nightmare to make an adapter for.
    The MP112 is a universal Magneson product:
    Magna Charger manufacturers intercooled supercharging systems for late model GM and Ford cars, trucks and SUVs utilizing OEM quality Eaton hybrid superchargers.
  18. #18 Re: Engine Is FINALLY Built! Added Pics!
    Rockford, IL
    I'd wipe that thing with a diaper, and put it in a glass case. That is gorgeous!!!!
  19. #19 Re: Engine Is FINALLY Built! Added Pics!
    Aug 2008
    Groveland,Fl
    Sweet engine I can only dream to many other projects right now
  20. #20 Re: Engine Is FINALLY Built! Added Pics!
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    DAMN! I dont even know what half that stuff is! Looks great!
    Ok no flaming but what is a Gen 3 PRJ Rails? What does it do?...
    This engine looks very expensive.....
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  1. s1x and built transmission
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2008, 04:56 PM
  2. installs and boxes built (unkind to 56k, pic heavy)
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 02-17-2008, 08:13 PM
