Thread: Turning + any throttle = hard vibration
Results 1 to 9 of 9
  1. #1 Turning + any throttle = hard vibration
    Feb 2009
    flintnasty MI
    Any throttle while turning causes a fairly significant vibration in the 01GTP I just resurrected (full motor/trans swap).
    Axles were on the car before hand, and had no issues....
    The trans mount is a ZZP poly unit... I imagine it may be causing some of the idle vibration I have (along with the motor being fairly fond of misfiring right now).
    The motor mount is new off a 05 (I figured they looked pretty much the same).
    The trans itself is completely an unknown, could have any number of issues, the motor/trans came out of a car that was hit in the front.
  2. #2 Re: Turning + any throttle = hard vibration
    Poly mounts will have a ton of vibration(this is basically what I've heard from several people)
    The donor car from which the trans came from was hit in the front end?? Don't think there would be much that would have been thrown off inside the trans... Maybe Bill will chime in here
    Snorlax strikes again.
  3. #3 Re: Turning + any throttle = hard vibration
    Feb 2009
    flintnasty MI
    I can rip it in a straight line, and it feels great.. but I get on it a bit going around an onramp, and the more gas I give, the harder it shakes.
  4. #4 Re: Turning + any throttle = hard vibration
    Ever had the cover off the diff housing? Ive exploded a diff before and they shake pretty good before the pin causes the diff to explode when they come out.
  5. #5 Re: Turning + any throttle = hard vibration
    Feb 2009
    flintnasty MI
    May check the diff soon.. I imagine it would be bad news if I ever did a 1wheel peel? (yes I sorta want to test it via a burnout)
  6. #6 Re: Turning + any throttle = hard vibration
    Could have shredded the gears in it.
    I had that issue when running some MT E/T's on the stock trans...right wheel let go and the left one didn't move, I ended up toasting it.
  7. #7 Re: Turning + any throttle = hard vibration
    Sounds like an axle from my experience. Especially the on ramp mention. Was either axle floppy at the CV's?
  8. #8 Re: Turning + any throttle = hard vibration
    Feb 2009
    flintnasty MI
    No, both were in the car when I got it... they were behind a perfectly normal and functioning turbo setup for awhile....
    I may have damaged them during the trans removal.. I was not nice to the pass side axle as I took the motor/trans out the top, together....
  9. #9 Re: Turning + any throttle = hard vibration
    Charles City, IA
    I second bill.
    SMGPFC Two Nipple General
  1. vibration at 55mph and hard steer
    By TheBeastGTP in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2010, 07:19 PM
  2. Vibration when turning right
    By amc401 in forum Brakes/Suspension/Chassis
    Last Post: 06-17-2010, 11:01 AM
  3. Noise when turning hard right over 30 MPH
    By probodyman in forum Introductions/Noob Questions
    Last Post: 12-04-2009, 08:22 AM
  4. abs light on = hard turning
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2009, 11:39 PM
  5. 1st! Vibration while turning '93 Lumina
    By Abrasive in forum Chevrolet Lumina
    Last Post: 01-06-2008, 08:36 PM
