Thread: power window question
Results 1 to 3 of 3
  1. #1 power window question
    SE Level Member mngtp's Avatar
    Crystal, MN
    I am wondering if its normal for the windows on the 2 door gp's to roll up slowly? Both windows seem to go up slowly but the passenger window is a lot slower than the driver side and sometimes it stops before going all of the way up, when it stops I have to let it down a little and try rolling it up again. The windows have be rolled up one at a time otherwise if they are done at the same time they barely move. Any ideas what could cause this?
  2. #2 Re: power window question
    the sliders and the regulators i bet are dry and dirty, you can pull the door skin and lube up all the moving parts, i like to use graphite spray, but silicon spray white lithium grease all that stuff works.
    or the motors are starting to die. when operating both windows they will go slower than one at a time, but what you are saying sounds like you need a lube job.
  3. #3 Re: power window question
    Crystal, MN
    Thanks. I will have to try lubing them up. When I say they move slowly when I roll them up together, I mean they barely move at all. Thanks again for the help.
  1. power window gremlins
    By Scottydoggs in forum General Tech Discussion
    Last Post: 07-05-2011, 02:52 PM
  2. One power window out
    By andante147 in forum General Tech Discussion
    Last Post: 04-26-2011, 02:33 PM
  3. Power window question
    By adurn in forum Audio, Security & Visual Electronics
    Last Post: 03-26-2011, 01:00 PM
  4. Power window stumper
    By pbrumfield2007 in forum Introductions/Noob Questions
    Last Post: 08-12-2009, 11:25 AM
  5. power window slash electrical question
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 06-22-2008, 09:25 PM
