Thread: Grand Prix stalls while driving
Results 1 to 20 of 20
  1. #1 Grand Prix stalls while driving
    My car randomly shuts off when driving. No sputtering, just instantly kills as if you were to just turn the key to OFF. I go to start it back up, and it just cranks and cranks and cranks. But if I wait about 15 seconds, it fires up right away. Then 10 minutes later it kills again. Seems like the 2nd time it dies, I start it back up after 15 seconds, go to drive away and it kills for a 3rd time. I get it started again and it will be good for another 10-15 minutes. When looking at a scan of the car when it is about to shut off, the first thing that gets disabled is the Injector pulse width, then the car officially kills and the rpms go to zero. BTW this 2002 grand prix gt has an L32 engine in place.
  2. #2 Re: Grand Prix stalls while driving
    Grand Rapids, MI
    did you notice the tach acting funny or dropping to zero prior to the engine dying?? im thinking cps maybe?
  3. #3 Re: Grand Prix stalls while driving
    GTX Level Member cerick08GP's Avatar
    bad crank position sensor
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: Grand Prix stalls while driving
    utah
    Cps it is
  5. #5 Re: Grand Prix stalls while driving
    GT Level Member Euro's Avatar
    Roselle, IL
    Yup. My car did this and it ended up throwing the CPS code.
    2000 Regal GS - 190k - Black over Storm Gray Metallic - 9" K&N/AL104's/Borla/GP polished tq stars/turd
    2009 Impala LT - 62k - Car Seat Mobile
    2000 Grand Prix GT - 96k - Sold/RIP
  6. #6 Re: Grand Prix stalls while driving
    I ended up driving the car for about 20 minutes today with no troubles at all. So hopefully it throws a code tomorrow. I'll have my scanner ready to go when it and if it does.
  7. #7 Re: Grand Prix stalls while driving
    Never Never Land
    Mine had the same symptoms yours does...no code though. Another CPS vote here.
  8. #8 Re: Grand Prix stalls while driving
    Houston
    Yup...mine didnt set off the CEL, but when I scanned it, it showed a CKP sensor fault. Another vote for the Crank pos sensor.
  9. #9 Re: Grand Prix stalls while driving
    If it kills again, I'm not going to fck around with it anymore and I'm just going to replace the cps.
  10. #10 Re: Grand Prix stalls while driving
    This is one case where a scanner probably won’t help you. When you lose the CPS signal the car thinks it’s off, and the PCM doesn’t record codes when the car is “off”.
    But hey you never know, at least your going to scan. People on here often think scanning their car will give it cuties or something.
    Just take that leap of faith buddy, it is your CPS. Maybe
    2008GP
    2002GP||sold
  11. #11 Re: Grand Prix stalls while driving
    Bunnell, FL
    there a write up for the cps?
    I'm a Sex Offender
  12. #12 Re: Grand Prix stalls while driving
    utah
    I think there's a write up for the cps...but its rather involved
  13. #13 Re: Grand Prix stalls while driving
    Never Never Land
    yes there is a write up...while it may look kind of hard....it's actually rather easy....took me like an hour and a half first time with having no clue what i was doing. I bet i could do it in 45 minutes now.
  14. #14 Re: Grand Prix stalls while driving
    GT Level Member RegalGS98s's Avatar
    NJ
    When you guys say CPS, do you mean the Crank Position sensor? CPS is the cam position sensor. CKPS is the crank. If you mean Crank Position sensor, I say another vote for it. My car was shutting off randomly and wouldn't let me start back up no matter what for at least a minute. I took the harmonic balancer off and checked the CKPS. It had some metal shavings between the teeth. I cleaned it with brake parts cleaner and wiped it down. Didn't have the problem afterwards. Worth a shot before replacing the sensor. You'll need an impact with good power and possibly a puller to remove the harmonic ballancer. I think I used M6x70 or M6x80 bolts with the puller. Just have to remove the plastic splash guard and the front passenger tire to access it.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  15. #15 Re: Grand Prix stalls while driving
    alright drove the car around tonight and the problem is still there. Luckily my SES light lit up. Pulled over immediately and scanned the code. PO101 is what I pulled.
    P0101 Mass or Volume Air flow Circuit Range/Performance Problem
  16. #16 Re: Grand Prix stalls while driving
    Never Never Land
    Im still sayin crank sensor with your symptoms.
  17. #17 Re: Grand Prix stalls while driving
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    can u update us was it the cps?
  18. #18 Re: Grand Prix stalls while driving
    Replacing the crank sensor did not help. I replaced it twice and it didnt help the random stalls. I figured out the PO101 was triggering the pcm to shut off, so i set the PO101 code to "no error reported" on my hptuners and the car never stalled again
  19. #19 Re: Grand Prix stalls while driving
    Jan 2013
    west palm
    howd you go about doing that?
  20. #20 Re: Grand Prix stalls while driving
    Quote Originally Posted by titanfan12 View Post
    You have to have hp tuners software to reflash your pcm. or some sort of tuning software.
  1. 1998 Grand Prix stalls after 3 seconds
    By dartrod in forum General Tech Discussion
    Last Post: 06-08-2011, 11:07 AM
  2. 97 Grand Prix GT very randomly stalls at idle
    By Deebo in forum General Tech Discussion
    Last Post: 02-20-2011, 01:09 AM
  3. '01 Grand Prix GTP won't start and stalls
    By tmac10 in forum General Tech Discussion
    Last Post: 12-02-2010, 10:26 AM
  4. 2001 3.8 supercharged grand prix stalls
    By reggis in forum General Tech Discussion
    Last Post: 09-26-2010, 11:04 AM
  5. grand prix starts, will not idle, stalls.
    By ibanez0110 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 01:20 PM
