Thread: Throttle body issue.
Results 1 to 20 of 24
  1. #1 Throttle body issue.
    Dec 2010
    DMV
    Ok I finally decided to clean my throttle body and maf sensor and i now I'm having issues with the car starting. I reassembled the throttle body and the cable for the throttle but it keeps popping off and now the throttle area is leaking coolant and car won't start anymore. Any help? Ideas?
  2. #2 Re: Throttle body issue.
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    can you post a picture??
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Throttle body issue.
    Dec 2010
    DMV
    I also installed a new gasket as well and scrapped off as much as I could of the old gasket
  4. #4 Re: Throttle body issue.
    Dec 2010
    DMV
    Unfortunately no. I had to catch the train to work because of the car not starting
  5. #5 Re: Throttle body issue.
    GT Level Member ill12will8's Avatar
    DC/MD
    i told you i had the same prob
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  6. #6 Re: Throttle body issue.
    Dec 2010
    DMV
    It's leaking though. Now the ***** won't start will lol.
  7. #7 Re: Throttle body issue.
    brunswick
    ok as for the leak im thinkin a new gasket for the tb is needed?? and for the cable.. did you happen to crimp the line under the bar coming across the motor.. i did that too
  8. #8 Re: Throttle body issue.
    Dec 2010
    DMV
    Ok I installed a new gasket and as far as the crimping it's possible but I don't think I did. Also it was smoking from the exhaust as well
  9. #9 Re: Throttle body issue.
    brunswick
    what did you use to clean it? and you may wanna list step by step how u did it so everyone can get a better understanding
  10. #10 Re: Throttle body issue.
    Dec 2010
    DMV
    Ok I used the crc throttle body cleaner and the crc cleaner for maf sensor.
    I followed the steps in the how to guide for the throttle body cleaning
  11. #11 Re: Throttle body issue.
    brunswick
    wow.. beats me man.. im trying to think only thing i can advise is to search these threads for tb problems.. im sure you probably have but still just throwing it out there... or check all the hoeses and sensors
  12. #12 Re: Throttle body issue.
    Dec 2010
    DMV
    I sprayed the maf sensor with the cleaner and cleaned the throttle body with a wire brush a rag and the cleaned It with the throttle cleaner
  13. #13 Re: Throttle body issue.
    Dec 2010
    DMV
    Is it possible the sensors are in the wrong connections? They only fit in the correct spot correct?
  14. #14 Re: Throttle body issue.
    brunswick
    i put one on backwards.. and crunk my car.. it reved up to 2500 rpm.. and i also left the vacuum line loose and my trans wouldnt shift
  15. #15 Re: Throttle body issue.
    brunswick
    i had the tps backwards and the idle control went bad..
  16. #16 Re: Throttle body issue.
    brunswick
    idk if sprayin the maf could have screwed up.. i didnt spray mine tho
  17. #17 Re: Throttle body issue.
    Dec 2010
    DMV
    Well spraying the maf sensor is the only way to clean it.
  18. #18 Re: Throttle body issue.
    brunswick
    yea true... i just had a lot of built up gunk on my tb itself.. but mann.. idk what to tell you
  19. #19 Re: Throttle body issue.
    GT Level Member sic6's Avatar
    san marcos, tx
    If your leaking coolant at the throttle body then it did not seal right. Try taking it off again and make sure it reseals properly when you go back to reinstalling it.
  20. #20 Re: Throttle body issue.
    Dec 2010
    DMV
    Ok thanks sic6! I didn't damage anything did I?
  1. LS1 Throttle body
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 05:16 PM
  2. throttle body
    By blown gt in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-08-2009, 03:13 PM
