Thread: Oil Pressure and Gauge
Results 1 to 8 of 8
  1. #1 Oil Pressure and Gauge
    GT Level Member ls1camino's Avatar
    Laurel, MD
    So, I hooked up an oil pressure gauge in my 2000 GTP. I installed the sender in the port where the stock Low Pressure sender was. The sender only had one wire out to the gauge (ground is through the case/threading).
    When the car is off and ignition off, the gauge needle rests on the edge of the gauge. When the car is on, it moves about a quater inch off of the edge, but doesn't even touch the 0 psi mark. I'm fairly sure I'm not at or below 0 oil pressure.
    This is not the only gauge I've installed in my two cars, so I'm fairly sure I wired it correctly. The only thing I did differently was not put the wire in wire loom. Could it be getting a false signal by touching the Firewall or something? Also, could the ground not being good cause this problem? Is the oil filter extension metal? Would it not be a good ground?
    I'm going to pull the passenger wheel off this afternoon to check to see if the wire is still attached to the sender (vibration may have rattled it off).
    Thanks for the suggestions.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Oil Pressure and Gauge
    PA
    You wouldn't be running for long at 0psi. I am guessing something is messed up with the wiring.
    You did run a new wire and didn't try tapping into the old one, correct?
    2001 GSE
  3. #3 Re: Oil Pressure and Gauge
    Laurel, MD
    Quote Originally Posted by Zef_66 View Post
    Correct, old connector is just hanging there next to the new sender.
  4. #4 Re: Oil Pressure and Gauge
    PA
    Quote Originally Posted by ls1camino View Post
    Did you use any kind of tape on the threads for sealant? That could be affecting your grounding.
    2001 GSE
  5. #5 Re: Oil Pressure and Gauge
    Laurel, MD
    I did...do you think I don't need it?
  6. #6 Re: Oil Pressure and Gauge
    PA
    You may want to only tape the first couple threads. You probably taped them too well and you aren't getting ground through the sensor.
    2001 GSE
  7. #7 Re: Oil Pressure and Gauge
    SE Level Member HEVEYMETIL's Avatar
    Western New York
    Although the grounding is done thru the metal of the case, I am going to go out on a limb here and say it might be a weak ground. Is there plenty of metal/metal contact? What brand of gauge are we dealing with?
  1. oil pressure gauge
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-09-2011, 02:00 AM
  2. Fuel Pressure Gauge
    By SDGTP99 in forum General Tech Discussion
    Last Post: 10-09-2009, 07:31 PM
  3. Oil Pressure Gauge...
    By mickey t in forum General Tech Discussion
    Last Post: 08-31-2009, 10:56 PM
