Thread: Wiper Home-Position
Results 1 to 8 of 8
  1. #1 Re: Wiper Home-Position
    ive never seen the wiper trans in a grand prix, but don't the wiper motor just have a L bracket bolted onto it and the trans arm gets snapped onto it?
    that's the way most of my cars that i have replaced the wiper motor or trans worked.
    if so hook it all up, and just turn the switch to off, and put on the wiper arms, in the down position, then run the wipers and see what happens. that's all i did on the last gm car i worked on. you may need to adjust them a little bit as to how far the blades are going to the driver side edge of the windshield, it may go past the glass. just remove the arm and turn it 2 or 3 splines the opposite way of the problem till your happy.
  2. #2 Re: Wiper Home-Position
    Topeka, KS
    This might help you.
  3. #3 Re: Wiper Home-Position
    PA
    Take your wiper arms off, turn the wipers off and let them park. Then install the wiper arms on the studs where they should be on the rests. Done.
    2001 GSE
  1. No vent position change
    By vince60 in forum General Tech Discussion
    Last Post: 12-28-2009, 12:10 PM
  2. Flywheel position
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 09:34 AM
  3. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  4. IAC Position
    By Reptile in forum PCM Tuning
    Last Post: 03-08-2008, 02:21 PM
