Thread: will a 99 Trans out of a park ave with 305s work?
Results 1 to 15 of 15
  1. #1 Re: will a 99 Trans out of a park ave with 305s work?
    Portland Oregon
    It's the electrical device on the lever. Some trans's have it inside the case.
  2. #2 Re: will a 99 Trans out of a park ave with 305s work?
    It's this dooooohickey
    Another thing to consider is if the trans lines are click or threaded. PA and the larger bodies typically had threaded in 99, while the W bodies were typically click. Easy to adapt, but something to keep in mind.
  3. #3 Re: will a 99 Trans out of a park ave with 305s work?
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    The one i was looking at doesnt appear to have that piece only the lever
  4. #4 Re: will a 99 Trans out of a park ave with 305s work?
    Not to worry. There's two 13mm bolts and one 15mm nut that hold that onto the shaft. The part will fit any 4T65E transmission and you can easily add it. Lemme get you more info.
  1. what hd trans will work in 02 gtp?
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2016, 11:45 AM
  2. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  3. Trans work for LS4
    By AzrakMCSS in forum General Tech Discussion
    Last Post: 07-13-2011, 02:13 PM
  4. Car goes in for work on the trans
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2009, 07:43 AM
