Thread: Trans work for LS4
Results 1 to 10 of 10
  1. #1 Trans work for LS4
    SE Level Member AzrakMCSS's Avatar
    Jul 2011
    Kinston NC
    This might have been hit on already but i didnt find anything. I know there are a few companys out there that work on the 4T65E-HD for the supercharged models but what about for the LS4 model? i know they are diffrent transmissions i would like to get mine Beefed up before i put the cartuneing turbo on it. Anyone know where i could go for this? thanks.
    There is no hunting like the hunting of man, And for those who have hunted armed men long enough and liked it never care for anything again. *Ernest Hemingway*
  2. #2 Re: Trans work for LS4
    LS4 is the GXPEEEE?
    If so, then yes, most of the same companies also build the LS4 V8 transmissions.
  3. #3 Re: Trans work for LS4
    Jul 2011
    Kinston NC
    Right, mine is in the Monte Carlo but should be the same. The sites ive seen all say for the 3800 series the trans should be the same-ish but mine has a trans mounted starter is the issue i keep running in to.
  4. #4 Re: Trans work for LS4
    A local had TEP build one for him. Loves it. I also heard that Raptor or some other place supposedly builds them.
    In reality it's the same basic trans with beefier parts.
  5. #5 Re: Trans work for LS4
    Jul 2011
    Kinston NC
    Ok ill look into those i also have a number for ZZP which ill call when i get off work. Thanks for the Info
  6. #6 Re: Trans work for LS4
    Call this number instead. 260-437-8912 Tell Dave I sent you.
    If you went with a ZZP trans (which they technically don't build), I'd suggest against having them install it. I know of a few that they "installer errored" on and they transmission have to come back out for various reasons like cross threading flex to torque converter bolts.
  7. #7 Re: Trans work for LS4
    Jul 2011
    Kinston NC
    ok ill do that. im assuming your name is Bill?
  8. #8 Re: Trans work for LS4
    You got it. He'll know who you are talking about.
  9. #9 Re: Trans work for LS4
    Jul 2011
    Kinston NC
    No answer atm ill call back when i get off work. one last question do u kno if they sell beefed up ones already put together? if so i can do the swap myself. Thanks again
  10. #10 Re: Trans work for LS4
    As far as I know yes and yes.
  1. what hd trans will work in 02 gtp?
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2016, 11:45 AM
  2. Will a 4T65E non HD trans work with a SC engine?
    By Charlie in forum General Tech Discussion
    Last Post: 10-28-2009, 10:04 AM
  3. Hi. Drive does not work. I think I need a new trans. Help please.
    By Freebeer187 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-03-2009, 10:00 PM
  4. Car goes in for work on the trans
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2009, 07:43 AM
