Thread: Cruise control question
Results 1 to 13 of 13
  1. #1 Cruise control question
    Jun 2011
    Sheboygan
    What possible issues would cause the cruise control not to work? wipers, winshield washer fluid, blinkers, and brights all work off of that arm, but the cruise wont hold or accelerate. Thanks again, these forums are helping me out a lot.
  2. #2 Re: Cruise control question
    having a burnt out bulb in the 3rd brake light will cause it to stop working
  3. #3 Re: Cruise control question
    Jun 2011
    Sheboygan
    one of the bulbs was burndt out, but that didnt fix the cruise. what should I look for to see of the cruise is hooked up by the throttle body?
    Thanks again
  4. #4 Re: Cruise control question
    Dec 2008
    philly
    look at the TB see if both cables are clipped into it, my cruise control one used to unclip it self all the time.
  5. #5 Re: Cruise control question
    Jun 2011
    Sheboygan
    both cables are connected, one for the throttle and the other I presume is for the cruise, any other thoughts? I really appreciate the help/ideas
  6. #6 Re: Cruise control question
    Jul 2011
    Western MA
    Have you topped off your cruise control fluid?
  7. #7 Re: Cruise control question
    Jun 2011
    Sheboygan
    cant believe I didnt think of that, should I check the muffler bearings and blinker fluid also
  8. #8 Re: Cruise control question
    Jul 2011
    Western MA
    Quote Originally Posted by Cobras 98 Prix View Post
    Don't think blinker fluid is the problem here
  9. #9 Re: Cruise control question
    GT Level Member 99GPGTP's Avatar
    Rome GA
    check fuses. if good disconnect the single brake light switch on your brake pedal, (there is a double plug switch and a single plug switch) jumper the connector and and test drive. if the cruise works then u need a new switch, if it doesnt then u have another problem... (this is what was wrong with my cruise)
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  10. #10 Re: Cruise control question
    Jun 2011
    Sheboygan
    Quote Originally Posted by 99GPGTP View Post
    where exactly would the brake light switch be located, up behind the pedal, and what do they look like, fuses were good
    Thanks
  11. #11 Re: Cruise control question
    Jun 2011
    Sheboygan
    ok, disconnected the single connector and put a jumper with a paperclip, still
    nothing, doesnt hold or accelerate. Any more suggestions
  12. #12 Re: Cruise control question
    Rome GA
    sounds to me like its a bad switch. need to get a wiring diagram and start doing electrical checks
  13. #13 Re: Cruise control question
    Jun 2011
    Sheboygan
    would I be better off getting a new cruise control/blinker/ arm from a junkyard?
  1. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  2. 2001 grand prix cruise control question
    By Old Pontiac Man in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2011, 09:09 AM
  3. Cruise Control Help !!!
    By avenger33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2010, 07:33 PM
  4. Cruise Control
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 07:16 PM
  5. Is this what you buy to fix cruise control?
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 05-16-2009, 12:08 PM
