Thread: Cruise control question
Results 1 to 13 of 13
  1. #1 Re: Cruise control question
    GT Level Member 99GPGTP's Avatar
    Rome GA
    check fuses. if good disconnect the single brake light switch on your brake pedal, (there is a double plug switch and a single plug switch) jumper the connector and and test drive. if the cruise works then u need a new switch, if it doesnt then u have another problem... (this is what was wrong with my cruise)
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  2. #2 Re: Cruise control question
    Jun 2011
    Sheboygan
    Quote Originally Posted by 99GPGTP View Post
    where exactly would the brake light switch be located, up behind the pedal, and what do they look like, fuses were good
    Thanks
  3. #3 Re: Cruise control question
    Jun 2011
    Sheboygan
    ok, disconnected the single connector and put a jumper with a paperclip, still
    nothing, doesnt hold or accelerate. Any more suggestions
  1. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  2. 2001 grand prix cruise control question
    By Old Pontiac Man in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2011, 09:09 AM
  3. Cruise Control Help !!!
    By avenger33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2010, 07:33 PM
  4. Cruise Control
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 07:16 PM
  5. Is this what you buy to fix cruise control?
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 05-16-2009, 12:08 PM
