Disconnect the wire harness going to the MAF sensor and try to start it. It may need a bit of pedal to keep it running for a minute but should eventually smooth out. If the MAF is bad and you disconnect it the car will run off pre-programmed tables. It is enough to get you home but don't race with it, run WOT or anything like that. Just be nice and gentle on it.
