Thread: will a 99 Trans out of a park ave with 305s work?
Results 1 to 15 of 15
  1. #1 will a 99 Trans out of a park ave with 305s work?
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    As the title states will a 4t65e with 305 gears out of a 99 park ave work in my 99gt with the pcm modified for the gears?
  2. #2 Re: will a 99 Trans out of a park ave with 305s work?
    Portland Oregon
    Yessir! As long as the both have the external range selector
  3. #3 Re: will a 99 Trans out of a park ave with 305s work?
    is that the lever on the top of the tranny?
  4. #4 Re: will a 99 Trans out of a park ave with 305s work?
    Portland Oregon
    It's the electrical device on the lever. Some trans's have it inside the case.
  5. #5 Re: will a 99 Trans out of a park ave with 305s work?
    It's this dooooohickey
    Another thing to consider is if the trans lines are click or threaded. PA and the larger bodies typically had threaded in 99, while the W bodies were typically click. Easy to adapt, but something to keep in mind.
  6. #6 Re: will a 99 Trans out of a park ave with 305s work?
    The one i was looking at doesnt appear to have that piece only the lever
  7. #7 Re: will a 99 Trans out of a park ave with 305s work?
    Feb 2009
    flintnasty MI
    You can swap your range switch onto that trans that has it internally.
  8. #8 Re: will a 99 Trans out of a park ave with 305s work?
    Not to worry. There's two 13mm bolts and one 15mm nut that hold that onto the shaft. The part will fit any 4T65E transmission and you can easily add it. Lemme get you more info.
  9. #9 Re: will a 99 Trans out of a park ave with 305s work?
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  10. #10 Re: will a 99 Trans out of a park ave with 305s work?
    What the..I swear I linked it too. Damn I need sleep
  11. #11 Re: will a 99 Trans out of a park ave with 305s work?
    Arvada, Colorado
    You did, in the other thread. I saw it and got 'er done.
    Sig2
  12. #12 Re: will a 99 Trans out of a park ave with 305s work?
    Thanks..
    Nice to know I linked a link to the thread of the link in the link.
  13. #13 Re: will a 99 Trans out of a park ave with 305s work?
    Arvada, Colorado
    Oh yeah. You get that sleep?
    Sig2
  14. #14 Re: will a 99 Trans out of a park ave with 305s work?
    Thanks a bunch guys!
  15. #15 Re: will a 99 Trans out of a park ave with 305s work?
    Arvada, Colorado
    Thank Bill, I don't know **** about FWD trans-axles.
    Sig2
  1. what hd trans will work in 02 gtp?
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2016, 11:45 AM
  2. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  3. Trans work for LS4
    By AzrakMCSS in forum General Tech Discussion
    Last Post: 07-13-2011, 02:13 PM
  4. Car goes in for work on the trans
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2009, 07:43 AM
