Thread: Wideband O2 confused
Results 1 to 10 of 10
SDGTP99 Wideband O2 confused 07-10-2011, 12:30 PM
Kejross Re: Wideband O2 confused 07-10-2011, 12:37 PM
SDGTP99 Re: Wideband O2 confused 07-10-2011, 12:40 PM
stealthee Re: Wideband O2 confused 07-10-2011, 12:44 PM
Bio248 Re: Wideband O2 confused 07-10-2011, 12:48 PM
SDGTP99 Re: Wideband O2 confused 07-10-2011, 01:18 PM
stealthee Re: Wideband O2 confused 07-10-2011, 01:19 PM
SDGTP99 Re: Wideband O2 confused 07-10-2011, 01:28 PM
z3r0 Re: Wideband O2 confused 07-10-2011, 01:40 PM
SDGTP99 Re: Wideband O2 confused 07-10-2011, 01:46 PM
  1. #1 Wideband O2 confused
    Wichita
    I'm looking at getting myself a wideband O2 gauge soon. But, I'm not clear on whether or not I need to get additional hadware to go with it. Im not even sure how exactly they hook up. Do I have to drill a hole and put in an O2 bung? Or does replace the front o2? May seem like silly questions to some but I honestly don't know thats why I ask.
  2. #2 Re: Wideband O2 confused
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I replaced the stock o2 with my wideband, I have the innovate lc-1 with gauge but others are probably the same... It has a "simulated narrowband" signal, I took my stock o2 and cut the wire harness off of it and got my power and ground and sent my signal back out all through the harness. And if ever need be I can unplug it and stick a narrowband back in easily... But most keep the stock o2 and if they don't have a cat use the rear o2 bung or have another bung welded in pre-cat.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: Wideband O2 confused
    Wichita
    Well I don't have a cat so its going in the rear O2 or a new bung. Ok thanks!
  4. #4 Re: Wideband O2 confused
    SWPA
    In order to get accurate readings the wideband 02 sensor needs to be placed a certain distance downstream of the rear head. Be sure to read the instructions for proper install.
  5. #5 Re: Wideband O2 confused
    supposed to be like 8-14" downstream. the best place is at the bottom of the downpipe.
  6. #6 Re: Wideband O2 confused
    Wichita
  7. #7 Re: Wideband O2 confused
    SWPA
    The UEGO's are the shiz
  8. #8 Re: Wideband O2 confused
    Wichita
    I picked a good one? Then I'll get it. =]
  9. #9 Re: Wideband O2 confused
    Bunnell, FL
    i just measure the length of the headers rear and downpipe
    32" downstreme from front o2
    w/o the extender pipe on the speed daddys 22"
    the aem says 18"
    so should i go get an o2 welded in somewhere in the downpipe on the ubend in the speed daddys now while the headers are still sitting off the car?
    I'm a Sex Offender
  10. #10 Re: Wideband O2 confused
    Wichita
    Speaking of headers I'm thinking of replacing my PaceSetters with Wbodystore stainless ones. The Pacesetters leak. I'm sure that would help with O2 sensor readings...
  1. confused
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-25-2011, 05:38 PM
  2. new and confused
    By kellyreap in forum General Tech Discussion
    Last Post: 03-17-2011, 08:35 AM
  3. Ok, now I'm confused.
    By Bluemagic in forum General Tech Discussion
    Last Post: 12-17-2010, 12:30 PM
  4. im new and confused
    By onetyme77 in forum Introductions/Noob Questions
    Last Post: 11-28-2010, 04:03 PM
  5. Confused!
    By tyno59 in forum Visual/Body Modifications
    Last Post: 10-29-2009, 09:17 PM
