Thread: Missing bolts?
Results 1 to 2 of 2
  1. #1 Missing bolts?
    MI
    I'm really hoping this is a dumb question but check out these pics and tell me that that isn't a missing bolt (trans mount?). I had this trans replaced about 2 months ago under warranty the shop has been so bad with attention to detail. I've been back 3 different times for my battery being loose (car wouldn't start), sway bar loose (huge clunks when turning), now I've noticed random noises coming from the front of the car. I went to look around and noticed the 1 O'clock positioned bolt was missing, along with that there are also 2 other bolts that seem to be missing in the 2nd picture. Not entirely sure about those two but my guess is they shouldn't be bolt-less. Unless they made extra bolt inserts...
    If you see something about "man drives car through Utah GMC dealership", it wasn't me...here is a link, it's legit no worries.
    Dropbox - Photos - Simplify your life
    08' GXP
  2. #2 Re: Missing bolts?
    there are 2 guide pins that go into holes in the bell housing, stick a small stick or something into the hole if it stops (shallow) thats the pins, if it goes in like a inch or so its missing a bolt. the pins should be one on the left side one on the right side. i think you have 5 bolts on the bell housing that you can see by looking at the trans where it meets the engine. hope this helps.
  1. arp head bolts or tty bolts?
    By Lacboi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2011, 10:51 AM
  2. Lower strut mounting bolts-- where to buy?
    By lightheat in forum Brakes/Suspension/Chassis
    Last Post: 08-01-2010, 08:56 PM
  3. PCM mounting
    By grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 03:50 AM
  4. how many bolts are there from the transmission to the engine???
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2009, 08:16 PM
  5. GPS Mounting
    By iflycessnas05 in forum General Tech Discussion
    Last Post: 06-26-2008, 08:36 PM
