Thread: A/C problem
Results 1 to 3 of 3
  1. #1 A/C problem
    SE Level Member Purplecupcakes's Avatar
    Jul 2011
    Pennsylvania
    my A/C doenst seem to be working.. it blows air.. thats about it.. i was told the unit may need to be recharged.. any suggestions?
    2000 Grand Prix SE, 4 door auto 3.1L
  2. #2 Re: A/C problem
    Windsor (ON) Canada
    It probably DOES need to be recharged.
  3. #3 Re: A/C problem
    SE Level Member jmt455's Avatar
    SE Michigan
    It might have a small leak and just need a charge, it might be a bad A/C compressor, or the compressor clutch or even the ignition switch.
    It's been my experience that adding refrigerant to a leaky system is just a waste of money. Find out what's failed and decide whether it's worth fixing.
    Lots of threads on this subject if you use the Search tool.
    Like this one:http://www.grandprixforums.net/air-c...sue-33087.html
    FWIW, when mine quit, it was a bad ignition switch.
    Blower speeds, DIC, DRL and sunroof were also affected.
    If the ONLY thing wrong is the A/C is not cold, it's probably not the ignition switch.
    83 Bonneville wagon
    08 G8 Base
  1. HID Problem
    By Dthreap in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2009, 05:05 PM
  2. HID problem
    By joshbarker in forum Visual/Body Modifications
    Last Post: 06-09-2009, 01:26 AM
  3. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
  4. How do i fix this problem?
    By thenervemann in forum General Tech Discussion
    Last Post: 11-01-2008, 01:49 PM
  5. well now its a problem...
    By the1euge in forum General Tech Discussion
    Last Post: 10-26-2008, 01:43 AM
