Thread: window motor
Results 1 to 2 of 2
  1. #1 window motor
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    Ok I am at a loss idont understand what's going on. Maybe someone will know I replaced my drivers side window motor and track about a week ago it was working great last night I rolled up my windows they went up fine this morning I go to roll it done nothing it sounds like it wants to roll up if it could go up anymore but when I click down nothing what's soever I got out the light tester wires and switch seem to be fine I just don't understand how the motor would just die like that over night. Any ideas?
  2. #2 Re: window motor
    SE Level Member jmt455's Avatar
    SE Michigan
    Do the rest of the windows still work from the Master (Driver's door) switch?
    If they do, then check the connector at the driver's window motor. One of the pins might have backed out or the lock might not be engaged.
    Also double-check the harness pin connections for the driver's window on the back of the Master switch. (Pin F, dark blue and Pin B, brown)
    Good luck
    83 Bonneville wagon
    08 G8 Base
  1. '02 GPGT DS Window Motor
    By Farmer Sparky in forum General Tech Discussion
    Last Post: 04-23-2011, 09:48 AM
  2. Window Motor 2dr Coupe
    By shawnschuldt in forum General Tech Discussion
    Last Post: 12-27-2010, 03:23 PM
  3. window motor?
    By bigdog853 in forum General Tech Discussion
    Last Post: 07-28-2010, 08:05 AM
  4. Window Motor Regulator
    By cutiger80 in forum General Tech Discussion
    Last Post: 12-15-2009, 09:09 AM
  5. Window regulator/motor
    By m1sterb0b in forum General Tech Discussion
    Last Post: 11-20-2009, 01:38 PM
