Thread: power window gremlins
Results 1 to 15 of 15
  1. #1 Re: power window gremlins
    is this schematic for a 98 regal? if so please sent it to gmc03scott@aim.com
    so basically your saying it could be the child lock switch not working properly?
    if thats the problem thats not to bad, as i was planning to replace the whole cluster of switches on the d/s door due to to all of them being well used and looking like crap.
  2. #2 Re: power window gremlins
    SE Level Member jmt455's Avatar
    SE Michigan
    Diagrams sent to your email.
    It could be the lock-out switch itself or a broken/open circuit in the 12V feed to the other switches.
    83 Bonneville wagon
    08 G8 Base
  3. #3 Re: power window gremlins
    thanks, ill play with that later.
    i did notice the lock out switch is sloppy loose but it still clicks when moved.
  4. #4 Re: power window gremlins
    found the problem, its the lock out switch for the back window child locks, i took the cluster of switches off the d/s door and tuned it over and gave it the magical wrap with the handle of a screwdriver and hit the other switch and it worked. the lock out switch is so loose its almost falling apart.
    so ill be just replacing the whole cluster of switches as planned some time ago, as they are all torn up and ugly.
    edit: i just wedged a piece of cardboard next to the switch, and it seems to be doing the trick, so thats my fix till i find the new cluster of switches for the d/s door. thanks for the help guys.
  5. #5 Re: power window gremlins
    SE Michigan
    glad to be of assistance!
    83 Bonneville wagon
    08 G8 Base
  1. One power window out
    By andante147 in forum General Tech Discussion
    Last Post: 04-26-2011, 02:33 PM
  2. Power window question
    By adurn in forum Audio, Security & Visual Electronics
    Last Post: 03-26-2011, 01:00 PM
  3. power window switch
    By eskimann in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2009, 06:46 PM
  4. Power window issues
    By dbinnc in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2009, 10:04 AM
  5. Power window ISSUES!
    By AR15 guy in forum General Tech Discussion
    Last Post: 06-17-2008, 02:09 AM
