should come loose, soak really well, heat if need?
i stopped using PB since i found out how kick*** GIBBS is.
They are in teh head right? So they are always heated. You shouldn't have any issues.
Sooo, you want to break them off?? Just soak em down and use a ratchet and deepwell socket and go to town. Mine came loose no problem. Maybe try and do it when it still has some engine heat left in the manifold.PB blaster and a pry bar
redline- what is this "GIBBS" you speak of? Like Joe Gibbs, lol... off to google I go.
Only reason I go for the pry bar is because my arms are about the size of noodles. So its really like a normal persons strength.
-BillyBoost you make sense with the fact there already/always heated up anyway heated up so shouldnt be an issue.
As for this GIBBS stuff I think a google is in order
