Thread: Reprogramed PCM's
Results 1 to 20 of 23
  1. #1 Re: Reprogramed PCM's
    Bastard Reptile's Avatar
    Kansas City, MO
  2. #2 Re: Reprogramed PCM's
    PA
    As for the ZZP issue. I have read accounts and helped out a lot of people on the other forum. Too many to count ran into problems with the trans, DIC, timing, DTC, etc soon after installing a ZZP PCM. Most of them, the issues went away when they went back to a stock PCM, or got a new one from ZZP. Again, can't say 100% for sure that ZZP PCMs are bad, but I know I wouldn't use them.
    2001 GSE
  3. #3 Re: Reprogramed PCM's
    Barksdale AFB, LA
    The only problem I had with my ZZP PCM was that its settings are harsh for 04+ transmissions. I took it back out and its sitting in a box. Someday I'll hook it up, pull the ZZP file to look at and see what they do to it, and keep the PCM around as a spare.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Reprogramed PCM's
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I started out with an Intense PCM = it was ok
    Then Rob Archer custom tuned my Intense PCM = much better
    ZZP PCM, in the car for about 10 mintunes = horrible, got a refund.
    A couple of custom tunes. = very good.
    My son has an Overkill custom PCM in his 99GTP = highly recommended
    IMO Overkill, is the only mail order PCM to consider.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: Reprogramed PCM's
    May 2008
    staten island,NY
    i originally had a DHP, my dyno guy couldnt read it so i bought an Intense pcm because they use HP tuners. now i have the ZZP pcm because of my M90 kit. best bet is to pick up an intense pcm and get a custom dyno tune from a reputable shop. dont go to some guy whos gunna charge you $300 for a "street tune", put it on the dyno and give it hell.
