A little update : I got out my scanner and turned on/off both cooling fans, so I know I dont have a bad ground etc. I watched the data and noticed that the gauge inside the car reads about 12-14 degrees higher than what the computer says it is. Ex. at 185 which is where the car normally is : the computer would say 172., is this a normal thing? I know not many people probably compare the two readings, but maybe this is correct and no one ever cares?
So when the computer reached 212 I did watch both fans kick on, so thats good. I guess I got nervous before and shut the car off, as the gauge would've read 225 or so.
I totally flushed out all the old dex and went with an all systems brand green. It's still running abnormally hot (207 computer, 220 or so via gauge) Ive been bleeding the air out, and it doesnt seem like theres more in there. But if the temp isn't right yet, I'm guessing there has to be something in there??
Ill try some more tomorrow and re-post.
