Thread: cleaning throttle body
Results 1 to 19 of 19
  1. #1 cleaning throttle body
    SE Level Member mtz956's Avatar
    browntown
    i removed da (iac) idler air control valve and it was nasty,should i remove da throttle body to clean it? can i spray carbuator cleaner when is installed?my car wont start and i have spark need to press da gas to be able to turn on. i can hear da fuelpump when i turn da key to on position. i havent check fuel preesure. going to. they told me to check da (iac) valve. it was dirty, im gooing to clean it to see if it works. should i clean da tb? thanks in advance.
  2. #2 Re: cleaning throttle body
    Holy english.
    Press F7.
    Year make and model of vehicle? Just take the TB off...its easier.
  3. #3 Re: cleaning throttle body
    SE Level Member TheManiac's Avatar
    Nov 2010
    Mentor, OH
    Cleaning the TB is probably not bad, but I have my doubts it's the root cause of your problem. I agree, if you are going to clean the TB right (as you should), take it off, other wise you're not going to get it all.
    Once the car is started, how does it run? Is it misfiring? By the fact it runs once started, we know you have air/fuel/spark. Pressing the gas is probably coincidence (since fuel injection should adress that). One guess I could make is a fuel line leak. When the car is off, the fuel leaks out the line, thus creating a problem starting (as you need to wait for fuel to work to the front and pressure build up). Just a guess, we need more info.
  4. #4 Re: cleaning throttle body
    My bet is a vacuum leak.
  5. #5 Re: cleaning throttle body
    Of course...what else can be happenin when da iac is out!
  6. #6 Re: cleaning throttle body
    Lots of race stuff...too complicated to discuss on here.
  7. #7 Re: cleaning throttle body
    Nov 2010
    Mentor, OH
    Shame on me, there I go missing the OBVIOUS source of the problem!!
  8. #8 Re: cleaning throttle body
    Seriously.. I'm thinking your issue is either fuel pump resistor or maf sensor.
  9. #9 Re: cleaning throttle body
    Donating Users squeaks130's Avatar
    Fargo, ND
    Quote Originally Posted by mtz956 View Post
    I'm not an English major, but really? I couldn't take it.
    I removed the (IAC) idler air control valve and it was nasty, should I remove the throttle body to clean it? Can I spray carburetor cleaner when is installed? My car won’t start and I have spark need to press the gas to be able to turn on. I can hear the fuel pump when I turn the key to on position. I haven’t check fuel pressure; I’m going to. They told me to check the (IAC) valve. It was dirty; I’m going to clean it to see if it works. Should I clean the TB? Thanks in advance
    Better? Its amazing what Word spelling and grammar check can do.
    But yea, I would guess fuel pump may be getting weak or a bad resistor. But more information would help.
    00 GT- Tint, Pre-gens, Hopes and Dreams
    91 F-150 4.9L, Pipes, tint, 2 inch lift, and 35's
    Little boys wear bow ties. Big boys drive FORD
  10. #10 Re: cleaning throttle body
    browntown
    ok sorry for spelling, da car is a 98 gtp 3.8 s/c and da car turns on but havent drove it like this. need to press da gas and da brake in order to move it. im going to clean da TB and da (iac) hopefully it works. next going to find da fuelpump ressitor. can someone post any pics to see where is located at.also its got a new (tps)throttle position sensor installed. 2 days before it died, da car was running like somehow accelerated. not alot but like 1300rpms. like if i was giving it throttle.
    thanks for da help
  11. #11 Re: cleaning throttle body
  12. #12 Re: cleaning throttle body
    Donating Users NoBoost91's Avatar
    Queens, New York
    Agreed ^^^^^
  13. #13 Re: cleaning throttle body
    Resistor connector is behind the headlight area
    Resistor..it's behind the washer bottle
  14. #14 Re: cleaning throttle body
    Fargo, ND
    grammar and spell check:
    Ok sorry for spelling, the car is a 98 GTP 3.8 s/c and the car turns on but I haven’t driven it like this. Need to press the gas and the brake in order to move it. I’m going to clean the TB and the (IAC) hopefully it works. Next going to find the fuel pump resistor, can someone post any pics to see where is located at. Also it’s got a new (TPS) throttle position sensor installed. 2 days before it died, the car was running like somehow accelerated. Not a lot but like 1300rpms. Like if I was giving it throttle.
    Thanks for the help
  15. #15 Re: cleaning throttle body
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    did you check the lil plug under your supercharger nose... it tends to drop off from time to time and will cause the problems your asking about
  16. #16 Re: cleaning throttle body
    Akron Ohio
    Quote Originally Posted by GTPSHAWTY View Post
    did you check da lil plug under da supacharga nose... it tend to drop off from time to time and will cause the problems your ax'n bout
    FIXED
  17. #17 Re: cleaning throttle body
    Akron Ohio
  18. #18 Re: cleaning throttle body
    brunswick
    what was the problem
  19. #19 Re: cleaning throttle body
    He's being a dick about your spelling.
    If you're referring to the vacuum line, its pretty different from an electrical connector as it has to create an airtight seal.
    In other news, this thread is from last year.
    Quite a long time to live with an issue like that.
  1. Cleaning Throttle Body
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2012, 08:00 AM
  2. Throttle Body Cleaning
    By Bryan921SS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2010, 01:44 PM
  3. Cleaning Throttle Body 04-GP
    By mpbrown18 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2010, 12:29 AM
