Thread: Can't figure out why my car won't start
Results 1 to 20 of 34
  1. #1 Can't figure out why my car won't start
    MA
    So I was driving a few days ago, and I felt the engine slowly die, the power steering locked up, the battery light came on, and it slowed to a stop and died. I replaced the alternator, and after taking the old alternator and my battery to Autozone, they confirmed that my old alternator was indeed bad, and my battery is fine. However, when I try to start my car I just hear a clicking noise coming from what sounds like the starter. My interior lights are fine, I'm getting power to my car, but it doesn't even crank. I even tried jumping it and it doesn't make a difference. Just a single click.
    I took the starter off (Although I accidently tried to take my AC compressor off because I didn't know what the starter looked like, I know I'm not the greatest with cars), and Autozone said the starter was fine. After putting everything back together, I'm stumped. Tomorrow I'm going to just call a mechanic and see if they can figure out what the problem is. Any suggestions on other things to try before I do that?
    I've ruled out the alternator, battery, and starter, unless I just have a bad connection somewhere or messed up when re-installing the alternator (I'm pretty sure I put the wires back on properly though).
    Any ideas?
    Thanks guys,
    Shane
  2. #2 Re: Can't figure out why my car won't start
    check the wires going to the starter.
    Then if you have a DDM, check the voltage when you turn the key to start the car, if the volts drop from 12.7ish to under 9 volts right away the battery may be toast.
  3. #3 Re: Can't figure out why my car won't start
    MA
    Called a mechanic and he said it's definitely the starter, even though Autozone said the starter was fine. *Shrug*
    Guess I'll change the starter out today and see if that fixes it.
  4. #4 Re: Can't figure out why my car won't start
    GT Level Member JessicaRebel's Avatar
    Jun 2011
    So.Cal: Victorville/Adelanto
    Quote Originally Posted by InfidelRebel View Post
    yeah ive learned to take what autozone says with a grain of salt. They told me one time my altternator was good but battery was dead. So replaced it, battery light was still on. I said f-it and replaced my alternator.. Light went off. I have heard other stories with people having the same issues with them.
    Hope you get it fixed and get your car going. Sounds like the starter to me.
  5. #5 Re: Can't figure out why my car won't start
    SE Level Member bstuby's Avatar
    charleston, IL
    Sounds like a loose battery terminal to me. You will still have power in the car but when you crank it it will just click. Its happend to me quite a few times. Check the connections on the terminals first before you throw down money on a starter. Make sure there clean and what not
    98 GTP/ SD Headers, 180 T Stat, AL 104's, CAI, Intense pcm, 3.4 thrasher mps
    98 TA, Pacesetter coated LT/ ORY/ LS6 Intake/ SLP Lid/ Magnaflow CB/ Tuned
  6. #6 Re: Can't figure out why my car won't start
    MA
    Well I changed the starter and still no difference. The starter was fine, when I started to remove it (But the electrical cords were still plugged in) I turned the key and the starter made a high pitched revving sound. But when the starer (Both the old and the new one) is actually installed, turning the key just makes one click.
    The mechanic is coming back tomorrow to look at it again. Hmm...
  7. #7 Re: Can't figure out why my car won't start
    another member here had their a/c compressor seize up and kept the engine from turning over, try removing the belts, turn the pulleys to see if they are all free, and of course, try to start the car with no belts on.
  8. #8 Re: Can't figure out why my car won't start
    thats what he said before....
  9. #9 Re: Can't figure out why my car won't start
    Never Never Land
    Sounds like a power issue to me. Once the starter is under load it isn't getting enough power to turn the motor over. Either that or you have some other accesorry that is locked up and not allowing the motor to turn over. My brothers 5.0 Foxbody wouldnt start because the smog pump was locked up on it. Removed the belt. Started just fine.
    Scotty beat me to it. One other thing i'd like to add is don't run the car long with the belts off. It will overheat since the waterpump wont be moving lol.
  10. #10 Re: Can't figure out why my car won't start
    MA
    I'll try taking the belt off right now to see if it runs. Also, after double checking the starter, I may have wired it wrong when I replaced it. Can anyone post a picture or diagram of how it's supposed to be wired?
    I did a google search and only found one diagram which wasn't clear at all.
    Thanks again,
    Shane
  11. #11 Re: Can't figure out why my car won't start
    MA
    I removed the serpentine belt and it still didn't start. Just made the single click. Still wanna look into the possibility that I wired it wrong, although the old starter seemed fine, so maybe it's one of the battery or starter cables. No idea how to diagnose that though. As I said, the old starter spun when I loosened it from the rest of the car, so power was definitely getting to the starter. But I took the belt off and it didn't make a difference in the clicking sound. Not sure what else to do. =/
  12. #12 Re: Can't figure out why my car won't start
    Never Never Land
    So it spun when off the car. You just put it back on the car right? You didn't mess with the wiring between did you?
  13. #13 Re: Can't figure out why my car won't start
    Houston
    Are you sure your crank isnt seized?
  14. #14 Re: Can't figure out why my car won't start
    MA
    No, I have no idea if my crank is seized. Or how to find out.
    And yes I did mess with the wiring, I had to when I switch out the starter.
  15. #15 Re: Can't figure out why my car won't start
    try to turn the motor by hand.
    try another battery too, just to make sure its not at fault.
  16. #16 Re: Can't figure out why my car won't start
    Have the battery terminals been checked for corrosion (if so, cleaned) and tightened up again?
  17. #17 Re: Can't figure out why my car won't start
    Jun 2011
    ^ is a very good idea.
    And like fivefinger said double check on the battery maybe take it somewhere else ( anywhere but autozone) and have them check, wouldnt hurt thats for sure.
  18. #18 Re: Can't figure out why my car won't start
    charleston, IL
    This is what I said a couple posts up. I've seen it happen alot of times. It's usually the easiest things.
  19. #19 Re: Can't figure out why my car won't start
    MA
    Mechanic came back and tried to turn it by hand. He says my motor is seized. Looks like I'll have to buy a new car... =/
  20. #20 Re: Can't figure out why my car won't start
    a used motor swap is cheaper than a new car, even if you had a shop do it.
  1. Trying to figure out what I can do
    By garreTT in forum Audio, Security & Visual Electronics
    Last Post: 09-03-2010, 10:53 AM
  2. trying to figure out...
    By CMURDAx in forum Off Topic Discussion
    Last Post: 05-30-2010, 10:40 PM
  3. cant figure this out
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 03:35 PM
  4. Cant figure this out
    By GTPJAY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 05:11 PM
  5. cant figure it out
    By dnomaam1 in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-09-2009, 12:39 PM
