Thread: Door Misalignment
Results 1 to 15 of 15
  1. #1 Door Misalignment
    Banned Trolling GPF
    I would like to start this thread by saying, my door is bothering me. I have compared it to my passenger side door and it is definitely misaligned one way or another. I recently tested to see if it let in dust, it does slightly around the weather proofing. It mostly lets it in in the far corner closest to the hinge.
    The misalignment is easily visible. I was wondering if there is any cheap way to fix this problem. The door does make a small squeaking noise when closing, not opening. I tried spraying some lubrication on the hinge all over, that did nothing.
    Thank you for any advice on fixing my problem.
  2. #2 Re: Door Unalignment
    new door pins?
    is it sagging because the door is so friggin heavy
  3. #3 Re: Door Unalignment
    Banned Trolling GPF
    new door pins?
    I have not checked, i will make sure to tomorrow. Thank you for your input.
  4. #4 Re: Door Unalignment
    My driver door makes all sorts of noise when you open it, but its not saggin, I tried silicone lube and it makes it go away for about a week or so then it starts creaking again. So if you figure out how to fix your let me know.
  5. #5 Re: Door Unalignment
    Banned Trolling GPF
    Quote Originally Posted by slick2500 View Post
    That has to be annoying. At least your door closes all the way though.
  6. #6 Re: Door Misalignment
    Houston
    Lambo doors....sag fixt. Lol
  7. #7 Re: Door Misalignment
    try lifting up on the door, if it moves then you need new pins or the whole hinge.
  8. #8 Re: Door Misalignment
    Banned Trolling GPF
    I will try that scotty.
    Keith, I think i already get ridden enough on these forums, that would only aggravate the situation.
  9. #9 Re: Door Misalignment
    Houston
    Not tryin to ride ya bro....was just fuggin with ya. I think this was a major reason they quit making the GP coupes. They couldnt find a way to support the doors.
  10. #10 Re: Door Unalignment
    Quote Originally Posted by jcmonteman View Post
    My car doesn't have the seat belt things and I dont even know how many times I have closed the seat belt in my door lol.
  11. #11 Re: Door Misalignment
    Banned Trolling GPF
    Yeah, I have closed my seatbelt in the door sometimes, but ever since I uninstalled the seat belt guides I have had no problem with it.
  12. #12 Re: Door Misalignment
    if its making lots of noise, its hitting the fender, which means your door is sagging and you need new hinges.
  13. #13 Re: Door Misalignment
    Banned Trolling GPF
    I checked it out today, my door is not sagging from what i can tell. When i pull slightly on it up and down the entire car moved. Door pin is my guess.
  14. #14 Re: Door Misalignment
    well since you cant just get the pin, you need the whole hinge. do i win yet?
  15. #15 Re: Door Misalignment
    Banned Trolling GPF
    Oh, I was not aware of that. I suppose you do win, only because you know everything and I know nothing though.
  1. HELP HELP! 99 grand prix 2 door DOOR HINGE REPLACEMNT
    By blortz in forum General Tech Discussion
    Last Post: 05-31-2011, 08:52 PM
  2. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
