i removed da (iac) idler air control valve and it was nasty,should i remove da throttle body to clean it? can i spray carbuator cleaner when is installed?my car wont start and i have spark need to press da gas to be able to turn on. i can hear da fuelpump when i turn da key to on position. i havent check fuel preesure. going to. they told me to check da (iac) valve. it was dirty, im gooing to clean it to see if it works. should i clean da tb? thanks in advance.
