Thread: Front wheel squeeks when wheel is straight.
Results 1 to 10 of 10
  1. #1 Re: Front wheel squeeks when wheel is straight.
    easy job. normally its always gunna be to the opposite side you turn, IF the sound go's away when going to the right its the left side and when turning to the left its the right side.
    Should be 5 lugs nuts, take the brake caliper off and rotor, then remove the 36mm axle nut, then the 3 bolts hold the hub/wheel bearing in. Its pretty simple. I'm syure there is a write up on the step by step prodcedure.
    remember to crack the 36 mm axle nut loose before you remove the rim or jack it up, unless you have a good air gun.
  2. #2 Re: Front wheel squeeks when wheel is straight.
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    squeaky wheel gets the grease, isn't here a phrase like that?
  1. I think I have a bad front wheel bearing-help please
    By dorkfish in forum Introductions/Noob Questions
    Last Post: 04-10-2011, 05:55 PM
  2. Front Wheel bearing on an 06 GT
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2011, 06:33 PM
  3. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
  4. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
