Thread: Instrument Lights
Results 1 to 9 of 9
  1. #1 Instrument Lights
    Michigan
    I have a 1997 Grand Prix and my instrument lights went out and I changed the fuse and see the instrument lights still havent come on. Could this possibly be the light control module? Whats the best way to troubleshoot the light control module? Has anybody had this problem before? The headlights work.
  2. #2 Re: Instrument Lights
    did the whole cluster go dead at once or one by one and now you got nothing?
    if so, you need to remove the cluster and on the back of it are the bulbs, you just twist the T's that are sticking out a bit to remove the bulbs. now's a good time to change the color of the dash lights if you ever wanted to as well.
  3. #3 Re: Instrument Lights
    Never Never Land
    Is it just the cluster lights that went out or did other interior lights go out too?
  4. #4 Re: Instrument Lights
    Michigan
    It was the instrument panel, steering wheel and the shifter panel that shows P,R,N,D. Seems it all went at once, like i said I changed the fuse because it was burned out and still nothing. All interior lights work o.k. and the headlights work o.k with the sensor.
  5. #5 Re: Instrument Lights
    Michigan
    I just researched my situation and see its the DRL module. I'm going to disable it when I get home and see if that was the problem.
  6. #6 Re: Instrument Lights
    FWIW if you burned out the fuse. That is typically the same fuse as the tail lights.
    If a wire in your trunk got mashed by a package..it's possible that's your fuse poppin issue. If GP's have the wires accessible in the trunk, that is.
  7. #7 Re: Instrument Lights
    us regal owners know about the pinched trunk wires for sure lol
  8. #8 Re: Instrument Lights
    Never Never Land
    Hmm. Never heard of the DRL causing that. Let us know how it turns out.
  9. #9 Re: Instrument Lights
    Michigan
    Well I pulled the fuse for the DRL and it had no effect on the problem which is no cluster lights. Anybody have any suggestions??
  1. 04+ Instrument panel in 97-03
    By nebgrandprix in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2011, 04:11 PM
  2. Instrument lights
    By flyboyray1 in forum General Tech Discussion
    Last Post: 02-17-2011, 05:32 PM
  3. Instrument Panel lights
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 12-25-2010, 07:54 PM
  4. Instrument Panel
    By iceman977th in forum Visual/Body Modifications
    Last Post: 12-23-2010, 04:04 AM
  5. instrument cluster lights
    By fasttmaxx in forum General Tech Discussion
    Last Post: 10-31-2009, 05:54 PM
