Thread: car overheating
Results 1 to 8 of 8
  1. #1 car overheating
    SE Level Member darkfox1009's Avatar
    May 2011
    Diamond Springs
    Hey guys, sorry I haven't been on in a while, but I've been working on my car. Anyways lol I need your advice once again. *insert meme* My car has been over heating recently. Not too much, but it goes up a couple lines over 210, (the half mark...just in case that wasn't clear lol) and I know that can't be good I replaced the Thermostat with a 180 degree one, and the hose off of it. There is no water leaks or anything. Also I fill everything up with 50% Coolant and 50% water "Dex-Cool" coolant like it asks and it says "Low Coolant" on my lights. I have no idea what is going on. Please help!! Thanks guys o/
  2. #2 Re: car overheating
    did ya bleed the air out?
  3. #3 Re: car overheating
    May 2011
    Diamond Springs
    yes sir, but only before I replaced the thermo. Do I need to do it again?
  4. #4 Re: car overheating
    yes you do, you took the thermo out and added air to the system, you need to bleed it again.
  5. #5 Re: car overheating
    half line is normal.
    thats where the high fans are set to come on with stock fan settings.
  6. #6 Re: car overheating
    May 2011
    Diamond Springs
    oh ok I'll try bleeding it, and then see how that does. I also figured 1/2 was normal, but it went like to the 2/3 mark and seemed like it was getting hotter. Also, something else that I noticed when I was going up hill at around 70 MPH on a freeway, is that white smoke came out of the back. Kinda freaked me out. It stopped after like 20 seconds, but I thought I put too much strain on the engine, and I did something. Hopefully nothing serious. Thanks guys!
  7. #7 Re: car overheating
    how are the LIM gaskets?
  8. #8 Re: car overheating
    May 2011
    Diamond Springs
    actually I havent checked it. Didn't think I needed to, but I will
  1. Overheating
    By Mr Darrell in forum General Tech Discussion
    Last Post: 06-13-2011, 10:50 AM
  2. overheating
    By mcdriver in forum General Tech Discussion
    Last Post: 01-24-2011, 01:24 PM
  3. Overheating!!
    By Pogo D Klown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2009, 03:48 PM
  4. overheating
    By famouspork in forum General Tech Discussion
    Last Post: 05-27-2009, 09:22 AM
  5. HELP!! overheating
    By sciontc1011 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:55 PM
