Thread: HVAC issues
Results 1 to 10 of 10
  1. #1 HVAC issues
    The Boss Iceman6669's Avatar
    Jun 2011
    So my HVAC has a couple of problems. I think I know what they are but wanted a second opinion.
    #1. My blower only works on the highest level. I Believe it is the BCM but not 100% sure. Any other thoughts?
    #2. My vent selection switch doesn't change the vents. It just kinda blows out of all of them. I have read in another thread that it was cause by vacuum hoses having a leak. If that is the case does any one know WHICH vacuum hose it would be. That would save me a TON of time searching. And if you don't think it is that what else could it be.
  2. #2 Re: HVAC issues
    swift current,sask.
    No, that's a blower resistor.
    The vacuum line if i'm correct runs up the drivers side wheel well by the strut tower and into the cabin. Someone should correct me if i'm wrong can't remember the last time i fixed one.
  3. #3 Re: HVAC issues
    Jun 2011
    Ok. where is the blower resistor located? Prob. on the blower motor right...
  4. #4 Re: HVAC issues
    swift current,sask.
    mhm, you gotter chief. Flip yourself upside down and shimmy under the passenger side foot well and you will find it.
  5. #5 Re: HVAC issues
    Topeka, KS
    Take off the kick panel or you wont' see either lol.
    #2 can be caused by a lil vac hose on the right size of the console under the dash or the Vent Actuators.
  6. #6 Re: HVAC issues
    Charles City, IA
    The vac line for the hvac system likes to break down buy the battery.
    SMGPFC Two Nipple General
  7. #7 Re: HVAC issues
    Jun 2011
    Ok well I am going to try to find the vac leak this weekend. And maybe check on the resistor too...Thanks for all the help guys.
  8. #8 Re: HVAC issues
    Oct 2008
    Calgary, Alberta
    For the vacume line I ended up using brake tubing to bypass the old passthrough, I went along side the shift selector for the auto transmission, and slit the foam/plastic noise barrier to minimize kinks in the line in the passanger compartment. This greatly shortened the length of vacumme line to the hvac system.
  9. #9 Re: HVAC issues
    Jun 2011
    Ok I spent like 4 hours on Friday night ( and a 12 pack) trying to find the nasty little vacuum line. And no luck. I cant find any problematic spots anywhere... I did not tear the dash apart however. Is that my next venture?
  10. #10 Re: HVAC issues
    If you need a resistor and have the dual/ digital controls i have one from a 99 gtp I'd sell you.
  1. Having issues with HVAC Fan, AC PUMP, ECT.
    By rynoman03 in forum General Tech Discussion
    Last Post: 03-21-2011, 01:39 AM
  2. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  3. HVAC Air Issues
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:59 AM
  4. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
  5. HVAC Issues.
    Last Post: 06-08-2009, 03:17 AM
