Ok this is the first time i have had to ever mess with AC. So hopefully somebody can help me with my issue. I get no cold air and the compressor does not turn on. I checked the fuses, diode, and relay that were all associated with the AC..they were all good. I then checked for voltage at the connector for the compressor with the car running....no voltage. I know the system pretty is pretty much empty. My first question is will there be no power at the connector of the compressor if the system is low? I would assume that there should...
